Top Creaking and clicking
Kevink820
Kevin
St. Louis, MO
2022 4door base
Anyone having the same issue as me and have a fix for it? sounds like my top is a 100 year old house. Creaks and clicks over every bump. no clue how to fix it
Function_7
James
'Berta
Just my Bronco
Do you have a roof rack mounted?
I run the oem rack with a light weight rtt in the summer, and I have some horrendous creaking over gravel roads and bumps.
Took the tent and rack off for winter, and roof seems to be making a lot less noise.
I thought the issue was the oem rack, so I was looking at other options, but maybe the problem is the roof?
Monster1926
GMC Sierra 2500HD
It’s the guide pins for the front two portions. I wrapped mine in electrical tape and it went away.
Arvitrekking
Tom
Bronco BD 4dr
Yup, same issue. I haven’t spent any time yet to try and fix it. My first thought is to clean and lubricate all the rubber with dry lube.
Function_7
James
'Berta
Just my Bronco
Mine is definitely not coming from the guide pins. It’s a squeak from inside the hard top itself, and sounds like it’s coming from behind the second row seats. It sounds like two pieces of styrofoam being rubbed together
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Ksjrb03
Tx
F250
That is the liftgate window rubber seal rubbing on top of tailgate. You need some krytox lube on there, every 6 months or so.
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
I was going to vote liftgate/window as well.
Grant3168
Grant
Denver, Colorado
2013 G37, 2006 G35
@Kevink820 have you ever found a fix for this? Having the same issue. Dealer pretty much said there is nothing we can do.
HP11
New Hampshire
2013 Boss 302 (sold) , 2023 Ford Bronco WildTrak
Yes, the noise was driving out of my mind! If its the clicking you are experiencing, then as Monster1926 mentioned its most likely the guide pins. I had this issue and I lubricated the seals and guide pins with Sil-Glyde and it worked perfectly for me. I've been "click-free" now for a couple of months. Hope this helps... here's a link to the product... https://www.amazon.com/dp/B000KXLR5E?psc=1&ref=ppx_yo2ov_dt_b_product_details
