Tire Pressure Range For Summer
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
No summer rating, only 39 for winter. Typically it's the same for the whole year but with the crazy temperature ranges I wanted to make sure I was getting the best mileage and use out of the tires. They were popping all the way up to 42/43 when the temp was in the 90's, and that just seemed way too high. Felt like it wasn't gripping well in turns.
Best tire mileage vs comfort is different and the fact you bought a Bronco means you really dont care about mpg.
kodiakisland
Arkansas
My dealer is a complete incompetent dumbass, that I want to divorce.
Brought it in for the safety recall. I asked them no less than 3 times to reset my tire pressures for Summer. They said, part of the inspection which they will do.
Dealer gave me the inspection sheet with the tire pressures set at 35. He did not touch them because they were EXACTLY where they were when I dropped it off.
Dealer is either incompetent or a liar, but probably both.
I guess they should have said WTF are you talking about? There is no special summer air pressure. If you don't like the tires at 35psi, either let some out or put more in. Why do you need a dealer to do that? If you wanted them to adjust them to 39, you should have said exactly that. They aren't mind readers. There is nothing wrong with 35psi, especially if you aren't riding at GVWR.
PSI is a function of weight rating. A simple concept that seems to be a difficult subject.
BlueBronco
DFW
I never heard of a summer or winter tire pressure. I would say it was a Northern thing but I used to live up there.
I keep my 37's at about 32psi and my 35's at about 36psi regardless of the time of year. And that's the pressure when the tires are warm not the season, lol.
Edit. This thread has got to be satire. Nobody really thought the cold reading on the door sticker was the winter air pressure, right?
Machz963
Travis
Detroit
'20 C8 Corvette, '22 Sasquatch 2.7tt, '08 Audi S4
I'm real happy at 35-36psi stock Sasquatch.
Same here, lessens the bump steer some on the two door. Seems to be wearing well. If you use Nitrogen you will see fluctuations, but not as much as just the air we breath.
jkburg
jkburg
Wisconsin
Acura 2020/2022 ILX, 2017 RDX
I think you are depending on your dealer too much. They are (legally) required to follow the established specifications for the vehicle. Probably as is Discount Tire. I don’t see “Winter” vs “Summer” tire pressures recommendations posted on the door frame placard. On road, off road, summer, winter, it’s up to you to determine what you want to run depending on ambient conditions. Don’t blame Ford or the Dealer,
While I agree with the relying on the dealer. My point was: 1) I specifically asked and they said they would. 2) they ran their multi-point inspection which that is one of the items. They crossed it off and said they set it at 35. Their is no f ing way Sasquatched tires should be at 35. My point was that they are liars.
jkburg
jkburg
Wisconsin
So go ahead and make fun of me, but is the tire pressure on the doors not Cold/Winter? Isn't it the same thing or are you saying Cold means not running for a while. If so then I have been duped for more than 35 years because that was my understanding.
  • Haha
Reactions: abe
kodiakisland
Arkansas
If the tires were at 35 and they said they were at 35, they are not liars. There is nothing wrong with 35, but again, if you wanted a specific pressure you should have told them, or better yet, do it yourself.
No. Cold means ambient temperature. Always has.
jkburg
jkburg
Wisconsin
No they were marked at 35. One was at 41, 38, 39 & 40. That was cold. Which as I said was exactly where they were when I dropped the car off-I checked right before and right after. I didn't want a specific pressure. See my statement below. PS, I do do it myself for every other car I own and have owned but again coming from a dealership that gives a shit (Acura dealer for 20+ years) they do it automatically.
ABSOLUTELY NEVER KNEW THAT! For 35 years of driving I always assumed that meant during driving in the cold temperature wise. I feel super F ing stupid about this.
AZ_Liberty
2007 Expedition
Cold means "before you drive" and not haven driven in several hours. Just like a "cold engine" means before you drive and not your engine temp in January.
Fill to 35 PSI in the morning before you drive to work, then measure your pressure when you get there. It will go up by several pounds per square inch because the tires, and the air in them, have heated up per the good old ideal gas law (PV=nrT)
Now in winter, you do have to put more air in your tires to get the same pressure, since the ambient air, and thus the tires are colder.
Headsong
Exactly. Now, how much oil do the tires take?
Yukon65006
Ken
Central WA
09 Jeep Patriot, 06 BMW F650GS
Maybe that did change out the winter air to summer air and forgot to note it on the work order. Summer air at 35psi is the same weight as winter air but has much higher boiling point.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
I run my SAS tires between 35 and 36 PSI cold. I do this because I feel I get the best ride quality at this pressure. As my tires heat up from driving, the psi rises to about 39 to 40 psi. This is the same pressure I used on my F150 Raptor as well. When I tried 39 psi cold, I seem to feel every bump in the road. :)
