Tire Pressure Range For Summer
Snowdogyyz
23 Ford Bronco Wildtrak
I’m betting the service department is having a ball with this!
  • Like
Reactions: abe
JBowles
Jordan
Ozark, MO
Ram 2500
PV=nRT
Learn it, Live it.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
22Badskwatch
Sacramento, CA
2022 Badlands Sasquatch
just got my badsquatch last night- tires were at 39psi and the ride was incredibly harsh - today, when it warmed up outside, they were at 46psi - so I dropped them down to 37 and will try that.
Los
Disco3
Don't kick yourself in the nuts, life also has a learning curve that needs to be calibrated from time to time....I just drove my 22 WT from Cali to AZ n the pressure on my tires was set at 45 psi, got great mileage, but it sure felt a bit bumpy at times (20 mpg) 2.7, I just lower the pressure. Going back I might increase it again, or just leave it at 36 psi.
BigBetty
Fai
Atlanta GA USA
While I agree with the relying on the dealer. My point was: 1) I specifically asked and they said they would. 2) they ran their multi-point inspection which that is one of the items. They crossed it off and said they set it at 35. Their is no f ing way Sasquatched tires should be at 35. My point was that they are liars.
Yeah they lied to me too. Wednesday I asked if they checked the tire pressure and set it as recommended by manufacturer. Guy said yes. I got in the car and it was at 40...just as when I arrived. Door jam clearly indicates it should be at 35. Liars. Probably didn't even change my oil because it was the day of the hack.
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
800 miles yesterday in new Bronco. Ride was ok but a bit stiff. Checked them 47 ouch. Air down today to see how it effect milage.
Digital_Synapse
2015 Mustang GT, 2022 Bronco, 2020 Explorer
Holy smokes. I run mine 31 cold so they heat up to 35. Great ride quality. I thought Ford fudged on the 39psi thing to cheat MPG.
Scott R Nelson
Meridian, ID
100%. Look at any Sasquatch with 5k+ and the center of the tires are dished, a telltale of overinflation.
Where did you get this "information" from? Did you just make it up?
I have 15,000 miles on my Sasquatch and typically my tires are at 38 psi cold. I drop the pressure off road, but less than 1/3 of my miles are in the dirt. I just went out and checked and there is NO difference in tread depth in the center of my tires. They are not "dished".
Do you have any facts whatsoever to back up your claim?
Tricky Mike
21 Bronco
I've seen hundreds of Sasquatches in person and every single one has been dished. Put a straight edge across the tread and it will be obvious. Most are bad enough you can easily see by eye. Once it starts it's really hard to correct.
I'm not running stock tires but this is what I do as well. Rides so much better at 30-32psi than it does at 35-38 psi cold, and tire wear looks good after 30k miles.
Also - yeah, important to realize there is a decent difference between cold and not-cold (driving around) pressures.
CarGuy
New Jersey
2023 Ford Bronco
35 cold…all year long. I may drop another pound to 34.
Roadbronc
Jerry
Northern ME
2005 Toyota Echo, 2014 Ford Mustang GT
I also am running 32F, 30R and I'm running 31's for tires. Seems to be the sweet spot for me.
