Those with the B&O sub- rattle fixes?
Combustion_King
Derek
MA
Yes
I took the entire panel off yesterday and put a bunch of sound mat on the metal, all around the sub enclosure, along the top and even some on the plastic panel. It still buzzes…. It drives me insane.
it def coming from the panel, did you guys sound matt the entire side panel Or what?
with what I’ve put on, it already make one of the clips not stay tight due to thickness of the sound matt.
help??
Jon_chimpo
Sacramento, CA
22 Wildtrak
Mine just started rattlin at 10,000 miles… This Bronco just keeps getting better with age.
Combustion_King
Combustion_King
Derek
MA
Yes
The rock music isn’t as bad, but any bass heavy songs are so bad sometimes at any volume half and up.
I’m gonna try to use that spray damping stuff in the inside of the rear quarter panel.
los7883
TX
Chevy Corvette
So I did the same thing, ended up covering the entire cargo area and still had the rattle. Tracked it down to the seatbelt mechanism, so I ended up covering that in KillMat and then also lined the area over the seatbelt. Helped out a lot but you can still hear it a little rattle at certain frequencies.
Ford Bronco Those with the B&O sub-  rattle fixes? E40467A2-A2B3-4BF5-B3D0-E77644AEB44A
Ford Bronco Those with the B&O sub-  rattle fixes? E894235E-64BE-4684-836D-4EBD215B7CC3
Ford Bronco Those with the B&O sub-  rattle fixes? C43EEC54-0AC0-4839-928B-6DD57E6CC986
I thought about adding some type of foam or something that'll actually absorb the sound but it doesn't bother me that much anymore. The Killmat sure helped get rid of like 95% of that rattle coming from there.
Ksjrb03
Tx
F250
It’s the stupid seatbelt retractor. Not much you can do after you Kilmat the plastic rattles which is easy and helps a lot.
Jon_chimpo
Sacramento, CA
22 Wildtrak
That’s fucking insane for a rattle. You’re the man though, looks killer.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Anyone know if I can remove the tensioner on a 2 door without any codes? I think the receiver needs to be plugged in with a clip in it, but hoping I can get rid of the belts with the rear seats.
los7883
TX
Chevy Corvette
Yea i actually opened up the seatbelt housing and traced that rattle down to these two pieces, the metal ball moves freely in that plastic cup...any sudden movement in the belt causes it to move and lock up the belt, can't do anything to quiet that down without running the risk of it not functioning correctly when you need it to.
Ford Bronco Those with the B&O sub-  rattle fixes? 7B386926-E319-4DEE-8F65-CB581AB0317F
And then this little black piece that bounced around all freely inside behind this white plastic piece. So yea there's nothing you can do about eliminating the rattle, only try your best to absorb the vibration and noise.
Ford Bronco Those with the B&O sub-  rattle fixes? 6FA9BA0A-11CD-42F8-B898-F1C3D8328E42
If you get bored you can read up on my hunt to eliminate the rattle here:
https://www.bronco6g.com/forum/thre...erior-with-killmat-sound-deadening-mat.64081/
los7883
TX
Chevy Corvette
That connector in the housing is crazy and a PITA to remove, never seen one like it but you can remove it.
Ford Bronco Those with the B&O sub-  rattle fixes? A4375FF4-6068-46F3-B7E1-1D2D9930010D
There are two white tabs on it, one on each side you'll push them in the direction of the red arrow and then pull off the 90-degree connector in the same direction.
Ford Bronco Those with the B&O sub-  rattle fixes? EE7E6124-70A3-466F-B560-C1BB7AE7681B
I know in Forscan you can disable the seatbelt reminders but not sure if it would throw any actual codes if you removed them altogether.
Murph914
Franklin, MA
Just seeing that makes me more worried. Those are the connectors for air bags and explosive pre tensioners. I read that as “don’t screw with me yellow”. Damn
Ksjrb03
Tx
F250
I was on a huge rattle battle last year and took that back seatbelt housing out for about a week, to verify it was the sole remaining rattle. Which it was. What a glorious week. It sets off the airbag light on dash when you remove the wiring to the housing.
los7883
TX
Chevy Corvette
Damn I thought it just controlled the seat belt reminders, it plugs into the seatbelt housing and nowhere else...idk.
Patriotic
Peter
'22 Bronco Wildtrak; ‘25 Porsche Carrera Cab; ‘20 BMW X5
I had my sub rattles professionally addressed by a reputable shop. Took half a day. Shop owner said main culprit was the sub housing assembly itself. He wrapped it and most everything around it with sound deadening material. No more rattles or buzzes.
broox
Derek
Des Moines, IA
broox.com
BMW M4, Bronco Badsquatch
i know this is an old thread, but i found some of the above helpful, so thought i'd add to it.
i managed to eliminate my rattles yesterday. here's what i did:
  • removed the side panel (these instructions were good)
  • made sure all the bolts were tight (they largely were)
  • added sound deadening to the wheel well, face of the sub enclosure, seatbelt tensioner, and a couple places of the plastic side panel
  • duct taped the plastic clips onto the plastic side panel to keep them snug
  • noticed that one of my blue clips was missing a foam washer, so i added some thin foam weatherstripping to it
  • silicon caulked the back of the sub grille to the side panel that it's welded to
  • added some thin weather stripping along the bottom edge of the plastic side panel
  • tightly coiled and zip tied my (unused) rear seatbelt in place
  • put weather stripping between my rear seat delete platform and the plastic side panels
i'm not sure which of these actually fixed the issue(s), but i'm now enjoying rattle free bass!
Ford Bronco Those with the B&O sub-  rattle fixes? sound deadening - 2
Ford Bronco Those with the B&O sub-  rattle fixes? sound deadening - 1
Ford Bronco Those with the B&O sub-  rattle fixes? sound deadening - 3
