This is a Bad Idea Right?
PrepVet
North Central WI
A bunch.
I do not have the tow package, but would have the proper hitch and trans cooler installed, what else would be needed?
2014 Pontoon Boat, trailer and outboard. Pretty sure it comes in right around 2800 - 3000 lbs. (would verify before I did any of this and there is ALWAYS something to "just toss in")
Ford Bronco This is a Bad Idea Right? Boat
2021 Bronco 2 door 2.3L auto with the rear locker.
Ford Bronco This is a Bad Idea Right? bronco
I normally just use my old silly truck, so this is not a need to do, just an idea that passed through my head as I have to do the brakes, again, on the old PW.
Ford Bronco This is a Bad Idea Right? truck
This was a lot easier when I had the Expedition where I could toss the entire family in and attach a trailer a go.
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
double axle trailer means its likely way more than your estimated weight, bad idea unless for very short tows.
PCDan
Dan
Park City
1968 Ford Bronco
Depends how fast and far you plan to pull it. If you’re just going down the road to the lake under 55 with no steep downhills, and under 4K lbs, you’re probably fine …. Otherwise nah
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
Take it to a good scale and get it weighed with a certification to carry with you. If something were to happen you will be held liable and your insurance will not pay. Jim.
Kenroofworks
Belton Texas
22Ford Maverick 08Ford F-250 Powerstroke 72 Bronco
The weight should be listed on your title or registration.
KABQ
Aaron
Albuquerque, NM
Fuck around and find out haha
mpeugeot
I towed one with my Bronco... I wouldn't recommend 80 MPH on the freeway, but it was only 3k pounds.
Ford Bronco This is a Bad Idea Right? received_623178405599281
It wasn't a problem at 55 MPH.
