The struggle is real.
I_Fly
Carl
MI
Bronco Black Diamond (2023) - Eruption Green
The picture says it all. So close yet so far. Guess I'll be shopping for a hitch mount with just a little more drop :). I did get it connected without too much fuss.
Ford Bronco The struggle is real. 1725500993264-rq
mcinfantry
Lee
Louisiana
Badlands 2 door
It’s far enough over the ball if you raise the leg it will slide on the ball and you can latch it….
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Same thing happens to me. I usually just put the hitch in an inch or two, attach the trailer to the ball, then move the whole thing forward to line up the pin. Kind of awkward…
bronco_billy
Indy
Crown Vic
I couldn’t take the struggle any longer, this solved the problem for me. 👍
Ford Bronco The struggle is real. IMG_2617
HolidayDog
Everglades
MT
24 Everglades
Everglades
Another SAS hitch / ball hack is just open the tailgate door. Drop it on and close the door.
I have a 1” drop and a 3” drop….i think the 2” drop will make my trailer level.
Cobrafang
Thomas
GA
Go longer and adjustable. Hehehehehehehe
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
Harbor Freight-$22
HAUL-MASTER 12 in. Hitch Extender
Ford Bronco The struggle is real. 1725536451125-fu
MayhemMike
Mercury
An F 150 eliminates the struggle.
Mdsuits
05 f350, 68 bronco 89 samurai
I ended up doing the turn offroad adjustable tire carrier and moved the spare up. (It allows for up and down and in and out adjustability)Even with a 37” back there I squeeze the trailer on.
Fordified1
Bob
Mid South Texas
Harbor Freight-$22
Just say NO to this option. Too much leverage on the hitch. A little more drop is all the OP needs though looks like it will drop on the way it is.
helifino16
Ron
Mount Sinai, NY (Long Island)
I had the same issue...
I pulled the locking Pin from the Hitch and locked that to the Trailer then pushed the hitch (and trailer) into the receiver. That convinced me that I needed 'Just a scooch' more drop.
Phil bronc
Phil
Edmonton
2023 big bend
Extend your hitch
mikec426
Russellville, AR
That thing with the handle that puts down or takes up the kickstand (don’t know what it’s actually called…) prevents this approach.
