Tailgate Rattle 2023
BuckBronco
Lansing MI
Ford Bronco
Anyone else have that metallic ticking noise on their 23s? I’ve read the threads for the TSB but I was built after the coverage date and it’s annoying.
Those that said they sprayed lithium grease inside their tailgate, are you talking around the exterior lip of the gate or actually inside the gate? I put a towel down on the hinge side corner and it dampened the tick so I’m assuming maybe it’s metal on metal in that corner but don’t see any wear.
Baseaf
Base Bronco
I have one. It is coming from the center of the tailgate and can't be replicated any other time except when I am driving. Drives me insane lol
BuckBronco
BuckBronco
Lansing MI
Ford Bronco
Same here… the insane part. 🤯
Lak34ers
Troy
Seattle
Spray the inside of the gate on the back side of the hinge bolts. Need a bottle with straw nozzle to be more accurate with spray and reach areas. There is another thread on this with pictures. Mine is a 21 so Ford has ordered me a replacement gate and hinges.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning. If you'd like to, go ahead and send us a private message with your VIN and dealer info so I can look into this rattle concern. Thanks!
BuckBronco
BuckBronco
Lansing MI
Ford Bronco
Been down that road… but thanks.
imstimpy
Austin TX
MY21 Badlands
Can you describe this rattle any more beyond "metallic ticking"? I'm chasing what sounds more like a "clunk" than a "tick". Only happens at low speed, doesn't necessarily happen over bumps (but might), doesn't happen by shutting the tailgate or shaking or banging or anything.
BuckBronco
BuckBronco
Lansing MI
Ford Bronco
That’s a different sound than what I’m experiencing. I scoured this forum and YouTube to figure out what my issue was. There are videos I’ve seen with the sound you’re describing. Do a good search and you’ll come across that issue I believe.
BuckBronco
BuckBronco
Lansing MI
Ford Bronco
Just for an update on the ticking issue… since the TSB doesn’t cover my model year and there were solutions I went ahead and used the lithium grease as outlined in the other threads and as of this morning, seems to have done the trick. I wasn’t thrilled at the prospect of spraying all of that into the tailgate but I’d rather live with that then the sound it was making. Im curious if Ford will acknowledge that the issue hasn’t been remedied in the future.
Baseaf
Base Bronco
Where did you grease it? Could you link the threads? Thanks!
BuckBronco
BuckBronco
Lansing MI
Ford Bronco
sonofhammer
Washington State
2023 Badlands 2 door
I have a 2 door 2023 and the tick started about 3k miles in. I haven't bothered fixing it yet.
The roof started clicking about 5k miles in. the fix for that is pretty straightforward tho:
You could even. use electrical tape.
BuckBronco
BuckBronco
Lansing MI
Ford Bronco
I haven't had the roof problem yet although my A-Pillar was rattling for a while but seems to have calmed down. In my last Bronco I thought it was the passenger seat but ended up being the seat belt rattling slightly. I had to tuck it in between the console and the seat. This has just been the metallic ticking of the tailgate and the grease seems to have fixed that.
I see a lot of people get on here and say that it's a Bronco and that rattles are part of owning an off road vehicle. While I get that, I'm assuming they dont deal with misophonia and some of us are really sensitive to these sounds/noises. I have a fan and a white noise maker running in my room at night to drown out any other little noises... I hear the heat kick on, or the ceiling fan tick, etc.
