Sway Bar Disconnect Wire Connector/plug type.
andersman02
Garrett
Minnesota
Bronco Big Bend 2.7l SaS
Does anyone know what type of wire connectors/plugs are used on the sway bar disconnect? There are 3 plug ON the disconnect, and 1 from the harness to the vehicle side harness. It does not seem that you can order this harness by itself.
Going to add a sway bar disconnect to a big bend and some of the ones I'm finding do not come with the harness.
PWillette
Parrie
Maine
@flip may be able to help...
andersman02
andersman02
Garrett
Minnesota
MB3Z-2B325-B
Very helpfull- Thank you! Would you by chance have the diagram and or/ harness part number that this plugs into (vehicle side)
flip
Phil
IN
www.ruxerparts.com
Fords
Depending on your configuration, the body side of the harness is the whole under hood mess. It's specific to your build date, engine, camera setup and fog or no fog. Those have a list price anywhere between $900-$1,100.
C1415 is a 12 cavity Molex MX150
Ford Bronco Sway Bar Disconnect Wire Connector/plug type. 1694107990700
Ford Bronco Sway Bar Disconnect Wire Connector/plug type. 1694108067899
Ford Bronco Sway Bar Disconnect Wire Connector/plug type. 1694107877352
C1416
Ford Bronco Sway Bar Disconnect Wire Connector/plug type. 1694108146828
PWillette
Parrie
Maine
Once again @flip produces...yet to be stumped!
andersman02
andersman02
Garrett
Minnesota
@flip
VERY nice,
Do you have the connector type for C1294A/B and C1295A/B?
This is for a 22 badlands VIN 1FMEE5DH0NLB10665
8rent
Brent
@flip
VERY nice,
Were you able to get the StaBar disconnect working like the factory installation?
andersman02
andersman02
Garrett
Minnesota
Nope, didn't even try, used an aux switch and happy I did. Very easy
jsoa
Jose
Delaware
2024 Bronco 4dr
which switch did you hook up to?
I assume when switch is off the sway bar is connected, what happens if the switch is on and you turn off the bronco? does it connect the sway bar again?
andersman02
andersman02
Garrett
Minnesota
1, yes if aux is on disconnect is disconnected. If you turn off disconnect is "connected"
Power to the disconnect means it will disconnect. There isn't a always on aux
RigOMortis
Niskayuna, NY
How did you wire it to your Aux - did you get the above harness (MB3Z-2B325-B) Flip posted and what other connnector(s) or wiring to tie in?
jsoa
Jose
Delaware
2024 Bronco 4dr
