Strange odor...
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
2023 BD Sasquatch - No mods - For the second time now right after a steady 69 mph highway cruise that lasted about 20 minutes, I'm getting an odor that (to me) smells like brake fluid. After a few ninutes it dissapates. No warning lights, no leaks in the driveway. Any suggestions?
have you looked around to see if there are signs of anything leaking anywhere or just going off your nose?
Lej512
Lej512
60th Anniversary
Larry
Queensbury, NY
60th Anniversary
I’ve looked. Nothing in the engine bay, nothing in the driveway.
MayhemMike
Mercury
First, check the brake reservoir level. If it isn’t decreasing there isn’t a leak. If it is decreasing, inspect each caliper for a leak. Also check to see if a brake fluid leak could drip on the exhaust which would create the odor but burn off and not create a spot on the driveway. Good luck.
Desmolicious
SoCal
2025 Bronco HE, MX5
Does it happen no matter what route you drive? To rule out it is a smell NOT generated by your Bronco.
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
I’ve noticed it a few times on mine during the past year It comes in and goes away in a minute or two with the AC on. 🤔
no fluid leak that i can detect.
Lej512
Lej512
60th Anniversary
Larry
Queensbury, NY
60th Anniversary
Route doesn’t matter. Should mention too 17k miles, never been off road.
Hmmm. Only 23 degrees here in upstate NY so no A/C. Driver’s seat heater on low, temperature on Hi and fan on 6.
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
Have you checked your cabin filter? Mine was horrible after only a few months usage.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Any work or service performed recently?
Lej512
Lej512
60th Anniversary
Larry
Queensbury, NY
60th Anniversary
zombie
New Brunswick, Canada
'21 Bronco '22 Mustang GT PP 06 Viper SRT10
I get a weird smell from the rear of my Bronco, but only in the winter, not sure if it's due to road salt or the exhaust or what.
Lej512
Lej512
60th Anniversary
Larry
Queensbury, NY
60th Anniversary
Wow! Wasn’t quite the picture I was trying to paint.
HoosierDaddy
__ Eric
NW. Indiana
Almost every newer vehicle I drive will at times have a coolant type smell, but not a single one ever has a sign of a leak or low level.
Personal cars, work trucks, other folks cars, etc etc.
I dunno ...
Ford Bronco Strange odor... 1f937-2642
