Steering Freezing Up <SOLVED>
SilverStreak02
Andrew
KCMO
22 Bronco Raptor - 02 Lightning
Has anyone else experienced or heard of this?
When driving between 55-60 MPH and making a slight right curve (1 degree or less) the steering seems to lock up. It takes a bit of extra force to the left to get it to release.
Strange thing is it seems to only happen at these two particular curves on this two lane highway I travel frequently.
Iā€™m familiar with wide tires tending to pull on wavy roads, and in fact I initially thought that is what was happening. But the more it occurs the more I realize itā€™s not pulling it just locks up.
My 22 Braptor is stock with 6K miles on it.
Ford Bronco Steering Freezing Up <SOLVED> IMG_2075
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
steering rack failure...warranty time
SilverStreak02
SilverStreak02
Andrew
KCMO
Yeah my gut thinks the same thing. Iā€™m worried I wonā€™t get the dealer to fix it cause they wonā€™t be able to recreate the issue. The curves it seems to only happen on is a 45 minute drive away from the dealer.
Was hoping it would be an easy fix but probably notā€¦.
RIDE
James
Wasatch
ā€˜23 Braptor, ā€˜71 Highboy F250, ā€˜54 Willys
Recall hitting any big hits/potholes at speed? I knocked my toe-in alignment out once and had something similar happen. Not on my Bronco though and it wasnā€™t an actual freeze. Would decide to track like it was on rails when I turned the wheel to an exact position. Realignment clears it right up
SilverStreak02
SilverStreak02
Andrew
KCMO
Thank you for the input! Iā€™ll have them check the alignment when I get in for oil change and tire rotation soon. Appreciate it.
MayhemMike
Mercury
Drive a different route and avoid the mysterious curves. Sorry, it is a steamy Sunday morning and I couldnā€™t resists. Hope you get it figured out.
RIDE
James
Wasatch
Btw, fully envious of that low miles on a ā€˜22. Iā€™m double that on my ā€˜23 through incredibly focused restraint and thought I was doing good. Thnx for the perspective and I feel like a failure now.šŸ˜‚
SilverStreak02
SilverStreak02
Andrew
KCMO
Iā€™ve only had it for a few months. Bought it used with 900 miles on it.
SierraBronco
2022 Bronco
This will be the dealers response šŸ˜‚
ā€œCouldnā€™t replicate. We suggest taking a different routeā€
SilverStreak02
SilverStreak02
Andrew
KCMO
@RIDE I want to thank you for the feedback. I measured and found that my LF toe was slightly in compared to the RF. Adjusted it and the Bronco not only doesnā€™t freeze in those two curves it actually tracks better in general.
I can only assume it was that way from Ford as the QC marks were in place and unaltered.
Appreciate the help. šŸ¤˜šŸ¼
tourproto
Portland, OR
2004 BMW e46
Mine does very frequently and I attributed it to the electric assist steering having millisecond hiccups responding to my steering wheel inputs. Steering is a totally "dead feeling" in the Bronco compared to my 2004 BMW 3 series. I just figured it was the electric assist motor not being very "smooth".
SilverStreak02
SilverStreak02
Andrew
KCMO
Have your alignment checked. I found my LF to be toed in slightly and once I adjusted it out my Bronco tracks so much better.
RIDE
James
Wasatch
Glad that was your issue. Relatively simple fixes are the best ones, I find.
