- First Name
- Phil
- Joined
- Jun 25, 2023
- Threads
- 38
- Messages
- 359
- Reaction score
- 414
- Location
- Plano Texas
- Vehicle(s)
- 2023 Bronco Wildtrak
- Your Bronco Model
- Wildtrak
Is there a way to hardwire a power cable?
For the Starlink that looks like a great power option. I like how it becomes part of the antenna to save space so you don't need to mount a battery somewhere else.
I would guess 8-10 hours. Curious how far my estimate is off.How many hours did you get using the Bluetti?
I saw this post of using a Molle panel to hold the starlink next to the roof for an easy no drill install, using the Turn Off-Road overhead molle panel.
Perfect. I think this will complete my starlink setup.
You will have to mount the molle upside down to have space for the mini, just something to keep in mind.For the Starlink that looks like a great power option. I like how it becomes part of the antenna to save space so you don't need to mount a battery somewhere else.
https://www.bronco6g.com/forum/thre...for-remote-camping.106167/page-4#post-2552108
Not my photo but this is my plan.
Where did you mount this voltage converter statlink power supply in your Bronco?
Sure. This may go without saying, but since your asking the question, just to be complete: You probably want it either through an upfitter or a relay keyed on ACC power, or it'll drain the crap out of your battery.Is there a way to hardwire a power cable?
I used the Revolink kit that includes a full crossbar that attaches to both roll bars. It allows you to mount the Starlink Mini in the center of the vehicle and just a couple of inches from the roof. I wanted it out of the way. It also has Molle panel attachment points on the bottom to attach other gear. You can barely see the bottom of the crossbar in the rearview mirror, so I like that it sticks it up out of the way. It is on the pricier side for the crossbar and quick disconnect bracket, but I am happy with it. Their customer service is also great as well. Had a mixup with some parts in the order, and they had me replacements out in no time.I just ordered a Starlink Mini an hour ago. This setup would work perfectly for me as I have 2 additional power options on that side.
Would you mind sharing a link to the ram mount and any accessories you used for this?
Does it seem solid so far? Good speeds? Can you get it closer to the roof line?
Thank you!!
