Special Tools Needed
Ducati1098
wonder why this part says it won't fit a Bronco?
Where does it say that?
Edit: Oh I see, on the ford accessories page.
It’s likely because they don’t let you narrow down the model further, and it will not fit a Bronco Raptor.
These will fit a regular Bronco though, just like the FP listing says.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Strange and then when I try to change vehicles it flashes and does all sorts of weird stuff...FordBot Revenge?
Ford Bronco Special Tools Needed 1736020247115-m5
Ducati1098
I think I understand what you mean now, see my edit on the previous comment
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
Ford Bronco Special Tools Needed 1000005082
Well after the help from a friend it is finished. Love the outcome. Loosened the UCA, Sway Bar End Links, and Outer Tie Rods and made it to where the knuckle could be moved to the side and used pry bars on the LCAs to get it on. Wasn't easy but it went in.
BoverW
J
Socal
Pass-through ratchet is a big time saver, reaching the top nuts. You will need it for the strut top nut and swaybar links, if taking them apart. You don't have to remove the fender liner.
Torque wrench
What torque wrench do you use for the rear top nuts? Tight space.
Robs
New hampshire
2023 Black Diamond
I try to get a feel for the right torque using the wrench on a more accessible fitting. I think I was able to do two of the three and then just used judgement on the innermost nut. I don’t think you can go massively wrong even without one
