Special Tools Needed
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
I was curious if doing a suspension swap from the base Big Bend shocks and struts to a Hoss 3.0 suspension system would require any special tools?
PWillette
Parrie
Maine
Other than an alignment post install, no special tools required.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
As mentioned above there aren't any special tools required but something you might not have that's really handy is a 4-6lb deadblow hammer to knock the axle shaft loose from the hub assembly such to avoid pulling your CV apart on accident. An air hammer works too but you can swing away like Sammy Sosa in his prime juicing days with one of those big orange deadblows and not worry about screwing up the end of the axle shaft or any collateral damage if your aim sucks.
On a similar note IIRC the axle nut is 35mm so you might not have an impact socket for those laying around either.
A good impact gun is handy especially when you get to the lower shock bolts on the rear as those suckers are torqued north of 300 if you've never had them off before
@V1Rotate says everything I would.
If you are fooling around with springs separate from shocks you may need a spring compressor. If they are takeoffs you shouldn't need to - it would just be like installing a coil over.
A pry bar / bottle jack or something would be nice, sometimes you have to muscle things back into place and maybe compress the shock or muscle the LCA around or something. A rope or something to tie pieces/parts up so you don't have to disconnect brake lines.
Nothing really major on there though. The coilover itself is only like 4 or 5 nuts - not much to it. Just have to get stuff around it off so you can get it off and on.
The rear the only thing you really have to do is remove the fender liner. That's the hardest part on the rear.
Tricky Mike
21 Bronco
Nothing special, but here's a tip. I've swapped out my suspension several times now and never once removed the CVs from the knuckles or dropped the LCAs, they are unnecessary steps IMO.
A bunch of CV nuts were over torqued from the factory stretching the threads and removal destroys the shaft. I choose to not roll the dice. If you do decide to do it that way, if the nut starts getting really hard to turn just stop and order a new CV right away.
Tricky Mike
21 Bronco
I'll be installing some front spacers, how did you swap suspension without disconnect of CV or LCA?
Disconnect the UCA and tie rod, flop the knuckle out of the way, and pry down the LCA. There's juuuust enough room. When you put the spacer in you won't have enough room to reinstall though, but I bet if you flip the lower shock bolts it will clear. They might have to be pressed out of the Bilsteins?
PWillette
Parrie
Maine
This worked for me tho I did have to loosen up the LCA bolts on the driver side to squeeze it in. Just be sure to mark your cam location prior to loosening.
MNBigfoot
MN
Sammy corked his deadblow hammer making only weigh around 3lbs,
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Awesome, thank you all for your help!
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Is there any nuts or bolts that I should replace?
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Pass-through ratchet is a big time saver, reaching the top nuts. You will need it for the strut top nut and swaybar links, if taking them apart. You don't have to remove the fender liner.
Ford Bronco Special Tools Needed 20240420_203707s
Ford Bronco Special Tools Needed 1735934506504-ty
