bschack
Bedford, NY
2020 BMW M550i
Not sure if anyone has done both, but what is the consensus as to which is easier to swap back and forth? OEM soft top or Bestop?
Interior guy
Dan
2022 bronco
Not sure it was covered here but I have badlands 4 door hard top and I bought the soft top and all brackets cargo panels and installed oem soft top all good but question is I’m gonna put the hard top back on for winter does anyone know if I need to remove any of the middle or rear roof locking brackets or can I leave them on when I put hard top back on? I was gonna put soft top back and unbolt three bolts on each side in cargo area was hoping to leave all other stuff in place for easier swapping and storage. Didn’t want to take off side channels or other stuff hoping someone can chime in Thanks in advance
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
You do have to take off the side channels on the C pillars. The brackets on the top of the roll bars can stay on with the hardtop.
Interior guy
Dan
2022 bronco
The plastics that are pictured up top? Oh though the guy said he forgot he left his on and wasn’t a problem? I was more worried about the brackets where the top pivots ?
Papa Smurf
Jax, FL
Those brackets are just fine. No need to remove.
moockd
Diana
Houston
Rear cargo cover removed on hardtop
Bolts for bracket behind rear cargo cover
Bracket for behind rear cargo cover
Bracket installed
Rear cargo panel with cutout for softtop, Right Side
Question - moving from hard top to soft top. Do I need 6 bolts? (3 on each side), or do I need 10 bolts (5 on each side, 2 for bracket and 3 for the soft top itself).
Thanks!
Papa Smurf
Jax, FL
Thanks!
Likely, only 4. 2 on each side for the support bracket. The other 6 SHOULD come with the soft top.
Interior guy
Dan
2022 bronco
So getting ready to put hard top on and to be clear is it necessary to remove those side channels to put hard top on? Do they get in the way? Don’t mean to be difficult but would like to leave on if possible so I don’t lose them or damage them
Strykerwsu
Wichita
Holden Commodores
No issues, Ford just saved cost in not including on hard tops originally.
huey
kevin
Ontario & Kentucky
yeah that is shitty. Why did Ford not save themselves money and only design one style of panels. This makes no sense to me
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
You will not need to remove any Brackets or those side panels to install the Hard Top. I just did this last week. The side panels are still installed and do not interfere with the Hard Top Install.
This makes it very easy to convert back to the Soft Top is you choose to in the future.
Catmandu
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
I can confirm. When we originally did the swap, we installed the hard top over the brackets and didn't realize they were missing. Since the original plan was to have a dual top option from the start, I suspect they were designed to stay in place.
RyanP
Ryan
Maryland
Mazda CX-9
Great write-up! Thank you!
For these side brackets - If you’re keeping your soft top too (I.e. - switching between seasons) can you leave these installed with a hard top on?
Thanks!
That's really helpful, thanks. Along those same lines, If you're going from a soft top to a hard top, do any of the brackets need to be changed or adjusted?
Catmandu
Catmandu
SW Florida
If I remember correctly, the HT prep kit included all of the brackets and we did not have to make any adjustments.
Interior guy
Dan
2022 bronco
Cool that makes me happy
