dgorsett
colorado
F250, Mustang, Explorer
All done for now! skid plates on, oil changed and re spooled the winch with tension.
Nice work, one of the best yet. Good Great idea tying into the intercooler/tow hook mount. Really could use that hawse fairlead/synthetic.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I plan to but I can't keep buying things this month. Really need to get pod lights first as my light bar no longer fits.
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
I dig that bumper. Very tight to the body.
I have this that I am looking to sell pretty cheap if you're interested.
Ford Bronco Snacktime's Broken Bronco Build 1689097322746
Talon2006
Houston
F-150l, 91 Eagle Talo n
You might of just motivated me to design a 4 Cylinder specific skid plate.
It's cool seeing someone fab stuff up!
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Pmed, warning I am pretty cheap...
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
It's sad that no one offers just a flat 3/16 steel option for us 4 cylinder broncos.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Bought some cheap NiLight cube lights off amazon for $20 a set. Quality is pretty good for the money and brightness is right in line with the price. They are brighter than factory high beams and flood pattern. These are not nearly as bright as my 40" rough country light bar that no longer fits but a nicer option for wheeling with others.
Ford Bronco Snacktime's Broken Bronco Build 1689878354047
Ford Bronco Snacktime's Broken Bronco Build 1689879388323
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Back to messing with the suspension again. Did a few quick measurements, some pictures and updated my excel sheet. Goals are a little more preload on the rear to help with handling and level her back out. I am looking at staying in the 3-4" lift zone to keep my belly from dragging(and so I can fit my big ass under the bronco while wrenching).
Looking at Moving the Front to 7 and the rear to 3 again.
Ford Bronco Snacktime's Broken Bronco Build 1690392960031
Current Ride Height in Blue
Ford Bronco Snacktime's Broken Bronco Build 1690393240910
Ford Bronco Snacktime's Broken Bronco Build 1690393265807
Leveled front to back
Ford Bronco Snacktime's Broken Bronco Build 1690393305187
Ford Bronco Snacktime's Broken Bronco Build 1690393325656
Squatted Bronco
Ford Bronco Snacktime's Broken Bronco Build 1690393430540
Ford Bronco Snacktime's Broken Bronco Build 1690393473633
Squatted Bronco CV angle
Ford Bronco Snacktime's Broken Bronco Build 1690393554427
Max droop
Ford Bronco Snacktime's Broken Bronco Build 1690393595821
Ford Bronco Snacktime's Broken Bronco Build 1690393615613
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Presenting the Big Gay Bronco! Riding slightly nose high, going to let it settle a little and see what the final height its.
Ford Bronco Snacktime's Broken Bronco Build WhRaHTkjvE_Te5kfjBroCpo=w1099-h618-s-no?authuser=0
First headache of the day was a frame mounted nut mounting a skid breaking loose and it taking me close to an hour to get the bolt out.
Ford Bronco Snacktime's Broken Bronco Build iJliz8M6YaSzxzbHlDNB08w=w658-h1169-s-no?authuser=0
Next was the leaky axle seal!
Ford Bronco Snacktime's Broken Bronco Build CFxsFDHE0mR_rz_ZMR__NJo=w658-h1169-s-no?authuser=0
Well the oil looked bad so I went shopping at lunch time.
Ford Bronco Snacktime's Broken Bronco Build qEgrPFXpr6BCCESlxDrBzOQ=w658-h1169-s-no?authuser=0
Yah my front diff oil was pretty bad... Ooohhhh lots of metal for 5k miles.
Ford Bronco Snacktime's Broken Bronco Build F9TeFhkvRth1qUI6axCBHxU=w658-h1169-s-no?authuser=0
Ford Bronco Snacktime's Broken Bronco Build Cd_SKZ3auKKc7PQWURevymw=w658-h1169-s-no?authuser=0
Small hiccup, missing some spring perch slots so I made a 1/2" HDPE to get that extra 1" of lift.
Ford Bronco Snacktime's Broken Bronco Build Mw3jmD1qg85535xpMqdghO4=w658-h1169-s-no?authuser=0
cynicalrider
First gen taco
Is that the first diff oil change since new?
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Yes first diff oil change, I will change it again in another 3-4k miles at the next service just to see if I am still getting metal.
cynicalrider
First gen taco
I'd say that's pretty average for new gear sets to be honest, nothing to be concerned about. When I put new gears in my Tacoma I dealt with similar shavings after break in. (y)
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I didn't get a picture of all the metal on the plug it was 3-4 times as much. Got a nice slug of crap straight out the bottom of the differential. I am not to worried, I just know that 37s + M190 = Bad Idea long term.
87-Z28
Andy
BMW
Do you know what the exact differences are between m190 and m210? Not basic marketing stuff. Are there any good engineering specs available?
