Steve-0
Steven
TX
2015 Chevy 2500HD Duramax
Updated with completed build photos:
We’ve all seen HodRods, RatRods, RestoMods, but…. ever seen mention of a RetroMod? This is what happens during a 20+ hour ride with your bride over a weekend. We have several amazing companies contributing to this to make it all happen. Lets see if they can turn our vision into a reality. A few have tried, I don’t think anyone has pulled this off yet to the degree we are shooting for.
RetroMod
/‘ret rō mäd/
adverb / noun The art of modifying a newer automobile that is imitative of a style, fashion, or design from the recent past with a modern flare: fashionably nostalgic or old-fashioned.
Lets RetroMod a new Bronco.
That’s a cool RetroMod.
This will be the build journal for my wife’s 2021 BadSquatch. We finally received this truck 2/2/22. We went straight from the dealer to our favorite trail system in the North Ga mountains. You couldn’t imagine the butt hurt we created on FB with an “aggressive creek crossing”. Hey, if we cant do Bronco stuff in our Bronco with our Bronco friends, we don’t want it.
She drove it for a few days before we sent it off to the folks at Glasslife Atlanta to work their magic. We found this inspiration photo long before we even ordered the Bronco. This is what we are trying to duplicate.
From this to this in just over an hour.
We are going all in and painting the panels. I’ve heard that “Wraps are for people with commitment issues”. Let’s hope we don’t have regret issues! LOL
While waiting on the body shop, we have installed King 2.5” Coil Overs w/Adjustable Compression. We also added Baja Kits Billet Upper A-Arms. This was followed by adding polished Method Wheels with General Grabber 35” tires. Sure, 37’s would fit but we will get more articulation from the 35’s. This will NOT be a pavement princess. We intended to use this truck the way Ford intended us to use it.
Here is a sneak peak of the body panels in the paint booth. This is Wimbledon White and Antimatter Blue.
I will do my best to keep this post updated with progress reports and pictures.
We are currently waiting on several parts. Hopefully we will have the Baja Kits Billet Rear Control Arms real soon. Plus we have several pieces coming from the guys at JCR Offroad. Future updates will include auxiliary lighting, winch install and a rear seat delete. Plus the painted surfaces will be covered in xPel Stealth Paint Protection Film and a ceramic coating.
UPDATE 3/19/22 Still need to finish wet sanding and polishing the paint. (Post 71)
UPDATE 3/31/22. Another teaser shot from the paint shop. You can kind of see what we are doing with the top and the illusion of different body lines between the top and the front door area of the top. Initially we planned to use vynil, but instead I made some carbon fiber panels that are bonded to the top.
Absolutely gorgeous!
7722 Bronco
Kentucky
2020 Explorer ST/ 2019 F350 CC DRW 4x4
Hi, my kc light bar just came in, did you drill or do something else for the wire?
I talked with the owner on Saturday in Tennessee. Asked the same question, he drilled and ran the wire. Said it was a very straightforward install, has it wired to AUX 2 on the upfitter switches.
Bemcnamara
Brad
Coeur d'Alene Idaho
2015 F56S MINI
Anyone know how the gas tank is attached? I have the Rough Country tailgate reinforcement which looks similar to what he has there. I tried some mounting solutions for the gas tank on it but was unsuccessful.
I was going to ask that same question.
FATHORSE
Stephen
okc
nissan
youre the only person I’ve ever seen running these badges besides myself, they look great! Especially on your build. Congrats!
Are these original or after market ? Where are they available?
Shane78
Shane
St. Louis
2D
FATHORSE
Stephen
okc
nissan
Phil
Phil
2022 Tesla Model 3 LR
RetroMod
/‘ret rō mäd/
Looks really nice. I wonder what edits were made by a moderator today at 10:58 AM ?
Ford Bronco RetroMod Bronco Build 1650941115125
Hatman
Argyle, Texas
Badlands Sasquatch 2.7L
Th
RetroMod
/‘ret rō mäd/
is looks amazing!!
ITLRUN
ITLRUN
Joe
Adairsville, GA
Several Fords
I believe they added the latest pics to this build thread.
ITLRUN
ITLRUN
Joe
Adairsville, GA
Several Fords
Looks amazing, man! The Wimbledon white and amb stealth ppf combo is stunning….so much so that for me you could even lose the red shackles and jerry can and this is still a stunner.
enjoy the props from everyone they are well deserved!
The shackles up front were only there for the show and I used them when strapping it to the trailer. I will not drive around with them making all that racket. LOL The RotoPax (jerry can) will probably be mainly used when out on the trails out in the middle of no where. Thanks for your kind words!
ITLRUN
ITLRUN
Joe
Adairsville, GA
Several Fords
ITLRUN
ITLRUN
Joe
Adairsville, GA
Several Fords
I bit the bullet and drilled through the bracket and windshield frame. I didn't want to run it through the weatherstripping or down the side of the windshield like one of the other manufactures recommends.
When drilling the hole I must have found a spot weld. It was a real PITA. I used plenty of cutting oil and a slow speed on my drill. The correct drill bit makes all the difference in the world. Then I clean all the oil residue and metal shavings and used some touch up paint on the body where I drilled through. I ran the wire through both the mount and the body. I put a ton of black RTV silicone between the body and the bracket. When I tightened the bracket down it pushed excess silicone out from the top and bottom of the drilled hole and the sides of the bracket. I cleaned up the "mess" on the sides of the bracket, but I left the excess on both sides of the drilled hole. This should prevent any water intrusion. This level of attention to detail can be found all the way through this build.
