Skid Plate Information Needed
jaroddf89
Jarod
Houston
2023 Wildtrak
Hey all. I am looking to do some off-roading soon but I understand I should get some decent skid plates before doing anything major so as to protect my vehicle. I have a 2D Wildtrak for reference. Can anyone give me a quick rundown as to what exactly I should protect and what to look for when shopping for skid plates? Any recommendations would be appreciated!
contented
Karl
Central Fl
BMW M2 Competition
Hi Jarod. Welcome to the forum. Skid plates are a big topic here. The following link https://www.cjponyparts.com/ford-full-body-steel-skid-plates-4-piece-set-4-door-bronco/p/SKIDP2/?year=2024&utm_source=bing&utm_medium=cpc&utm_campaign=Best COS Shopping&utm_term=4583451684401234&utm_content=Best COS gives you an idea of what factory skid plates cover. These came on my Badlands. I added a transmission skid from Talons Garage. The factory set up plus trans skids have served me well when wheeling in Colorado and Moab. Use the forum’s search function to broaden your knowledge.
Enjoy your new Bronco. Take care.
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
Ford makes it ridiculous to fill in the skids when you already have the front.
I want the gas tank, but alone they price it out of reach, so you buy a whole set, which you don't need and you're spending money on 2 skids you then have to sell.
Anyway, I've trying to figure out the best way to go about this, and I keep going back to RCI, because it's cheaper and easier, but I'd prefer the 1 piece OEM.
Ford sucks when it comes to additional mods after purchase. They really don't get it.
MNBigfoot
MN
If you have a 4 door, get the OEM skid plate kit through Ford Acessories with a 25% discount, works out to about $650, and comes with a decent gas tank skid plate. A 2 door Wild track should already have the tank skid plate so the OEM kit isn't worth it. If you look at the aftermarket kits, most exclude the gas tank skid or charge $600 extra for it. The OEM kit doesn't come with a trans skid. If you have Ford points, you can use them for the purchase.
DriveAllNight
Dan
N.J.
IS there a 25% off now?
DriveAllNight
Dan
N.J.
Bummer!!! Back order, can't do it!
Ford Bronco Skid Plate Information Needed 1732505301004-7
Tricky Mike
21 Bronco
Check local classifieds for an OEM bash plate and engine skid, people take off perfectly good skids all the time for upgrades. Then buy whatever flavor of trans skid that tickles your fancy.
Here's a great view of my skids, all OEM except the trans which is a cheap Mabett and the DV8 shock skids. That's the essential set, you can get LCA and diff skids but they are a waste IMO. These will get you through 7 rated trails all day.
Ford Bronco Skid Plate Information Needed IMG_20241017_184555
DriveAllNight
Dan
N.J.
It worked today !!!!
I guess they restocked - LOL
And thanks @MNBigfoot for the discount code !!
Skid plates on the way - With that said it looks like the front 2 skids will be up for sale if anyone needs the ones I already have.
MNBigfoot
MN
It comes on a long wood pallet about 6', weighs a lot, if you have a pick-up or trailer, bring it.
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
25% off (652.50) is a great price ,since cost is $609 -- since i work at a dealer i ordered one beginning of Oct,cost plus 10% =669.
DriveAllNight
Dan
N.J.
That picture was without/ before the discount.
DriveAllNight
Dan
N.J.
Didn't expect that. I was thinking it would fit in the Bronco, good to know ahead of time.
Thanks.
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
If you have the V6 I’d do the transmission crossmember skids and rear shock skids. Those are a couple spots it’s common to hit that hang low. I have RCI for the crossmember and DV8 for the rear shock, which also provides a little protection for the rear of the lower links.
B22-2023
Houston
Agreed. People forget the transmission crossmember skids - very exposed crossmembers made of chintzy metal I’ve beat up pre-skids. Yes and rear shock skids, first get - at the level of eliminate double honk, it’s an obvious easy fix.
