Skid plate bolts
Blaven
Pennsylvania
I was changing my oil today and I noticed the 4 bolts holding the skid plate on over the oil pan are getting a little corroded. Does anyone know the size or part # for them? I tried searching on here and on google but i didnt find the exact bolts that are on mine. TIA.
Two different sizes depending on location - but m8 1.25 and m10 1.5 I believe. Nothing special about them - can get replacement at the hardware store.
Blaven
Blaven
Pennsylvania
Thank you. All 4 looked the same to me when I compared them. They were 15mm, I was just unsure of the thread and length.
Alternatively, if it's just a bit of corrosion - you can wire brush them to clean them up and use a bit of anti-seize on them when putting them back in.
Felix808
SRV CA
Should be M10 x1.50. Only thing special about them is the they have a tapered tip and captive washer, but any M10x1.50 will work. Just take one with you when you head to the hardware store to verify 🤠
Valhalla
Valhalla
Chattanooga Tn
I shoot mine with paint after I clean up from wheeling...
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
Any good stainless replacements out there? Might be good to have an anti-theft version depending on where you live.
