Show me your poke!
Tomleo67
Tom
Mass
22' big bend 4 door
You probably want to look for a 8.5 to 9" wide wheel and the offset around +12 to +30. When you start to get around -6 or 0 or +6 it will start to poke quite a bit. You may need to run Sasquatch flares as well since they are wider and will cover up some of the poke. 20" wheels might be a little tougher to find the combo you want so post up whatever you find and someone will give you an idea of how much they will poke.
OK Thank you! looks like I may go with Falken A/T4W 35x11.5x20's ON Lock 50 cal 20x9 wheels with 0mm offset and I will probably change the flares to sas
JL8jeff
Ewing, NJ
Here's my truck with the 35x12.5x17 on 17x9 -6 offset wheels. Your tire would be 1" narrower so 1/2" less poke and the 0 offset would be another 1/4" in so that would be 3/4" less poke than mine. My tires stick out 1-3/4" past the flare so you would still stick out 1" past the Sas flares like I have.
Ford Bronco Show me your poke! bronco_comp7
Ford Bronco Show me your poke! bronco_comp6
Tomleo67
Tom
Mass
22' big bend 4 door
THANK YOU! Great info! Does that give you any issues with that much poke as far as rain/dirt/mud?
JL8jeff
Ewing, NJ
There is some spray but not as bad as I thought it would be. I do have some mud flaps up front and my truck has the hoop steps which actually block a lot of spray/debris.
Ford Bronco Show me your poke! bronco_comp9
swamp2
Anyone want me to "pollute" this thread with aftermarket wheel poke on my Raptor?
JL8jeff
Ewing, NJ
17x9.0 -25 non-sas fender
With that being -25 offset, the 0 offset would be around an inch more inward than this but that should give a good idea that the 0 will still poke a bit.
Tomleo67
Tom
Mass
22' big bend 4 door
ok thank you. I think with the bigger flares I'm hoping to be around 1 inch or less like you said.
Fordified1
Bob
Mid South Texas
35/12.5/17. 17x9 +12mm. Non SAS flairs. Pic before Eibach coilovers.
Ford Bronco Show me your poke! IMG_8080
swamp2
Zero offset KMC wheels, stock tires on Raptor. Just about what I wanted for poke.
Ford Bronco Show me your poke! PXL_20240211_213853734
Ford Bronco Show me your poke! PXL_20240211_213924285
Ford Bronco Show me your poke! PXL_20240211_190102090
Oldhippie
Barry
Santa Cruz, Calif.
Ford Bronco Show me your poke! IMG_3055
Ford Bronco Show me your poke! IMG_3058
Ford Bronco Show me your poke! IMG_3046
Zero offset Icon Rebound pro 17x8.5 0 offset wheels, MT Baja Legend 37x13.50r17 tires, Zone 3” lift…little more than I like but livable
Bellime
Keith
2022 Ford Bronco
My ICON’s with 0 offset
Ford Bronco Show me your poke! IMG_2060
