Secluded Maintenance: Brake Fluid Change
ecasazza
Everett
NJ USA
Pilot, Avalon, Corvette
Hello all,
The service schedule recommends changing the brake fluid after 3 years.
I am approaching the 3-year mark. I would appreciate any thoughts experiences and costs.
Thank you
Everett
ChrisB351
Shreveport, LA
Brake fluid is hydroscopic and will build moisture in the lines. It also loses its viscosity over time with heat. Most manufactures recommend changing it every 2-3yrs.
NC_Pinz
Central NC
I used to dismiss brake fluid changes, but I've come around over the years. I have no idea the cost but will be doing it for mine and typically do it for my other vehicles.
ChrisB351
Shreveport, LA
Cost shouldnt be more than $200
adam1991
VW GTI (2)
Hello all,
Thank you
Everett
DOT 3/4 brake fluid is hygroscopic. Do it.
lmarchetti
Luke
I just did the 3 year flush this past weekend.
Took 3 bottles of Motorcraft PM20 brake fluid. I will buy 4 bottles next time, just to have extra on hand. About $15 each.
You will need a pressure bleeder, 20 PSI worked well for me. I have Motive Power Bleeder with 1100 adapter for the bronco.
Procedure for me in the 2.7 was,
Remove debris filter & drain master reservoir.
Reinstall debris filter & refill master with fresh fluid.
Hook up pressure bleeder with 2-3 16 oz bottles of fresh fluid.
Enable brake maintenance mode.
Flush both rear brakes.
Disable brake maintenance mode.
Cycle emergency parking brake 5x.
Bleed rear brakes again.
Bleed front brakes.
Disconnect power bleeder & install cap to master.
Unfortunately for the 2.7 the service manual says follow on screen prompts on the diagnosis tool. So I had to use my best judgement.
If you have a 2.3 it gives you exact instructions.
Hope it helps! If anyone has screenshots of the diag tool instructions that would be killer.
23_Badlands
US
'25 Tacoma Limited, '23 Bronco 2d SAS 7sp(AB) High Tow Modular Hoop
For what it's worth, Broncos use LV (low viscosity) DOT4 brake fluid, not the standard, off-the-shelf DOT4. The brake reservoir cap says use DOT4. However, there's small imprinted text on the brake reservoir itself that specifies LV DOT4 fluid.
timhood
Tim
Several
Hello all,
Thank you
Everett
In NJ, you probably should follow the 3-year time interval. This recommendation is conservative, so it's not the end of the world if you go past it. DOT 4, particularly the low-viscosity kind in the Bronco, is much more resistant to water absorption than DOT 3. Out here in this dry climate, brake fluid can last much longer than 3 years. Test kits are cheap and are worth getting so that you can be aware of the condition of your brake fluid.
Kevfra
Kevin
2023 Bronco
Hello all,
Thank you
Everett
Do it. Tell you what, if you don't want to believe me, go to Amazon and buy a $5 moisture tester for brake fluid. After three years you have water which means you are already starting on corrosion. On my motorcycles (hard braking) I flush every year, and on my cars every three years.
timhood
Tim
Several
I've been waiting a day for someone to explain to me the difference between secluded maintenance and scheduled maintenance. 💀 When do I choose one over the other?
Ford Bronco Secluded Maintenance: Brake Fluid Change Screenshot 2024-11-13 at 9.27.10 AM
Bschurr
NY
+1
FYI - Porsche standard is annual brake fluid flush. Regardless of manufacturer’s schedules/interval, flushing your fluid is inexpensive and good preventative maintenance.
timhood
Tim
Several
Well, it's actually two years for Porsche, but there's also a reason why they recommend two years for their high-performance sports cars that are frequently taken on the track.
I'm not sure what you consider inexpensive, but unless you are doing a brake fluid flush DIY, I wouldn't call it inexpensive. (And I wouldn't recommend DIY for someone not comfortable with bleeding a brake system.) It'll probably cost nearly $200 at a dealership, and surely over $100 even at an independent shop. And the most expensive kind of maintenance is the unnecessary kind. A brake fluid tester costs a tiny fraction of that price and pays for itself immediately.
timbits588
WNY
2017 Expedition EL Limited, 2023 F-150 Lariat, 2023 Bronco Wildtrak
Not to derail the thread, but do you have anti-lock brakes on your motorcycles? Curious if you need a device to activate the system to get a full flush?
Kevfra
Kevin
2023 Bronco
I do, but no device is needed if you know the procedure.
thesocalexplorer
Joe
Southern California
Appreciate the procedure attachment @lmarchetti . Does anyone know if the 7MT procedure would be different, with the clutch being plumbed into the MC?
My first manual transmission, but have plenty of seat time DIY bleeding my older vehicles.
