Sanity Checking Offsets (-12)
ronnyek
San Luis Obispo Area, CA
2023 Bronco Wildtrak, 2018 Mustang PP2
I'm struggling to understand or visualize what this offset would look like on the bronco.
I'm ready to pull the trigger on some wheels that are
17.8.5, -12 offset, (4.28" backspacing)
and I'm thinking of going with a 35X12.50R17LT for a tire.
The wheels are a good look, but I dont want something where the face of the wheels is near the outer rim lip of the wheel (no concavity) and I dont want them sticking out a huge amount either.
Does anyone run a 17x8.5 with -12 offset? I've seen people that are running wheels from same mfg that are 0 offset, but it does not appear they offer these wheels that offset.
JL8jeff
Ewing, NJ
Here's a couple of pictures I grabbed off here showing some 17x8.5 with -10 offset which is just 2 mm less offset than the wheels you're looking at. They poke out a bit, even with the Sas fender flares.
Ford Bronco Sanity Checking Offsets (-12) bronco_17x8.5ray102
Baja Bronco
2Sun AZ
Are your flares grey? Or just the pic? Looks pretty cool!
Baja Bronco
2Sun AZ
I’ve always gone 0 offset. The offset will determine the “poke”. Some will have more, some less.
5GENIDN
Idaho
Do you have sasquatch?.... you have a wild track... so I believe that you do.... Some one correct me if I am wrong but I believe all sasquatch wheels are a +30 offset. that means if you were to put a measuring tape perpendicular against your tire the new tire location would be 1 and 1/2 inch further outboard.
JL8jeff
Ewing, NJ
That's not my Bronco, just some pictures I grabbed for reference when I was looking at wheels. Offset/backspacing/wheel width all work together to determine how much "poke" you will end up with. That's why it's always good to ask questions about different combinations. I do have pictures of several combos I saved if anyone needs to see. My Bronco has 17x9 with -6 offset and 35x12.5x17 tires.
Ford Bronco Sanity Checking Offsets (-12) bronco_comp4
Ford Bronco Sanity Checking Offsets (-12) bronco_comp7
ronnyek
ronnyek
I ordered the wheels so I hope they aren't tooooo bad **crossing fingers**
waystinthyme
Jonathan
Chicago
21 Bronco Badlands
how are you liking these procomps?
JL8jeff
Ewing, NJ
So far so good. They are so much easier to clean than the stock Sas wheels but I only have 5K miles on them in the last 18 months (it's my daily driver but I don't leave the house every day) so I may not be the best scenario to judge them for any fading or wear and tear.
waystinthyme
Jonathan
Chicago
21 Bronco Badlands
thanks! they look amazing. I ordered a set.
74broncosport
scott
clarinda
24 badlands 22 willdtrak
Upgraded yesterday to this exact specification. Ko3 throw way less rocks.
Ford Bronco Sanity Checking Offsets (-12) 20250613_201302
Ford Bronco Sanity Checking Offsets (-12) 20250613_183022
