RokBlokz Mudflaps Review
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Bro Flaps for the win. $80 shipped.
Ford Bronco RokBlokz Mudflaps Review IMG_2660
Ford Bronco RokBlokz Mudflaps Review IMG_2656
AK SNO RIDER
Ty
Alaska
Apparently I didn't take a pic before I took them off, but I put my 315/70 Patagonias on today and the front flaps DO NOT CLEAR. 8.5 wide 0 offset wheels.
So stock tire size with an offset change won't clear these flaps.
I'll be modifying them to work, but they really need to redesign the front flaps.
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Mine shipped today & I have 9” wide +01mm offset wheels. Sounds like I might be sending mine right back.
AK SNO RIDER
Ty
Alaska
Yup if you don't want to modify anything should probably send them back.
Sucks cuz I've been recommending Rokblokz products for years but this one is a miss.
1975U15
2019 F-350 SD, 1975 Bronco
Where are you rubbing? On the bracket or the flap??
Clear zone must be somewhere between +12 offset and 0 as I'm at +12 on 18x9 and 295/70's and clear fine. Good luck.
AK SNO RIDER
Ty
Alaska
Catching the thumb screws and slight rubbing on the flap. On flat concrete, would only get worse with flex. I'll get a pic for reference this evening. Been needing to pull and swap to the new gold clips anyway.
AK SNO RIDER
Ty
Alaska
Clearance with bare bracket:
Ford Bronco RokBlokz Mudflaps Review 20220505_221056
Clearance with flap and thumb screws. This is flat concrete and you can see the lug squished against the thumb screw.
Ford Bronco RokBlokz Mudflaps Review 20220505_221316
Not much clearance to be gained even if I modify the flap because of the rock rails.
Ford Bronco RokBlokz Mudflaps Review 20220505_222028
I'll see what I can do about it but so far these are a no go with 0 offset wheels and a more aggressive but stock size tire.
Bucker
Neal
El Dorado Hills
2021 Base Sasquatch
My Rek Gen Sasquatch. $120 fronts. No cutting, movement, rattles or rubbing. 35 inch BFG. Took 15 minutes per side for install. Recent hard core 4 wheeling and protected doors well.
Ford Bronco RokBlokz Mudflaps Review wEHM5Qy3RwqQers7rviz%A
Ford Bronco RokBlokz Mudflaps Review rP53ZqIkQQOL6iDlzrx6J
Ford Bronco RokBlokz Mudflaps Review Ev4jgjGdTk2I9z7xZD9loQ
AK SNO RIDER
Ty
Alaska
Took some effort but we're making progress here. Haven't done the drivers side yet but after several beers I've got the passenger side on and clearing with the thumb screws.
I thought at first I'd get away with just swapping the thumb screws out for button head screws but that was a no go.
So I removed the plastic block behind the fender liner like a another member here (@Bradley Thornton) had mentioned doing. As far as I can figure out this things only purpose is to provide a place for a couple of the liners push pins to grab hold.
This makes lots of room for adjustment of the RB mounting bracket, but the problem then is the flaps run into the rock rails. So...out comes the Dremel.
I'd suggest moving your cars outside before firing up the dremel, because at some point your little cutting wheel will shatter, shoot across the garage and play a round of pinball between the wall and your GT350 🤦‍♂️ (like I said, *several* beers were involved with this job)
Now everything seems to fit. Still on level ground but I'll get it flexed out some this weekend and see what things look like.
More work than it's really worth and I'd tell anyone with these on order and plans to go to more aggressive wheels cancel their order.
Ford Bronco RokBlokz Mudflaps Review 20220505_224630
Ford Bronco RokBlokz Mudflaps Review 20220505_224640
Ford Bronco RokBlokz Mudflaps Review 20220505_232940
Ford Bronco RokBlokz Mudflaps Review 20220505_232933
Ford Bronco RokBlokz Mudflaps Review 20220505_232949
Ford Bronco RokBlokz Mudflaps Review 20220505_234723
Jjt24
JJ
Toledo Ohio
Escape, Mustang
So I removed the plastic block behind the fender liner like a another member here had mentioned doing. As far as I can figure out this things only purpose is to provide a place for a couple of the liners push pins to grab hold.
It does look like you'll have plenty of room now even with flexing. You'd think Ford could've made that plastic and rock rail flush with the body panel from the get go...
AK SNO RIDER
Ty
Alaska
Yea, you'd think.
Forgot to mention I also removed the middle layer of the flap assembly to gain another fraction of an inch.
Not really sure why RB chose to make the flaps a 3 layer sandwich, but removing the middle one seems to have no ill effects.
TX-Hans
Looks nice, much cleaner fit, and how you'd expect them to look from the get-go, but that looks like a fair amount of custom work to get something pricey to fit cleanly. Really glad I sent mine back.
GreenMtnBronco
West Nyack NY & Central VT
'21 BadSquatch; 04 Lifted Mini
based on your post, I just received mine and have already put in the request to send back.
i have nitto ridge grapplers 37x12.5 on Fuel Vectors at 17x9 -12,.. no way these are going to fit based on all the comments. I did have an exchange with the co where they did a good job of convincing me they would be fine.
GreenMtnBronco
I installed my standard Rokblokz with crash bar on my stock badlands last night. I assembled everything on the kitchen table and then went out in the garage for bracket installation. I didn’t turn my wheels or remove any tires, I was able to install where it sat. The fronts went on just fine, The flaps don’t quite mount at a parallel/perpendicular angle to the rest of the truck, the inner edge angles back a bit. I tried adjusting the brackets, but they were already maxed out for angle. I don’t have any movement in mine like the OP here. The passenger side flap sticks out about 1/4” farther than the drivers side flap, which I prefer for additional coverage, I couldn’t adjust the drivers side out at all. When I swap to my +35mm wheels I might need that little bit more coverage. The rears bolted on just fine and are very solid. I slid them out as far as they would go and it’s just right. One of the body mount bolts requires a small socket with a narrow universal adapter to get back on without scratching the bracket. On the angle of the rear flaps, Rokblokz could reduce one of the angles on the brackets and the flaps would sit closer to vertical. I thought about straightening mine with a vise, but I didn’t want to damage the powder coating. Overall I would give these a 4 out of 5 star rating, with the fronts getting 3/5 and the rears getting 4.5/5. The fronts could stand to feel a little more solid, be square to the truck, and have some adjustability. The rears could have the bracket angle reduced so that the flaps don’t kick back as much. I would also use all stainless hardware for assembly (not sure if the current hardware will rust) and throw in the 8 screws and washers for those looking to ditch the quick release knobs.
looks like you have diff set of wheels/tires in the background to be installed? what size tires are you going with and did the RB give you problems w them?
BroncoBarn
Illinois
2002 Wrangler
The mud flaps are the least of your worries.
