RokBlokz Mudflaps Review
Jjt24
JJ
Toledo Ohio
Escape, Mustang
I'm happy with mine and I'm ok that I paid the price I did. They seem to be made of quality material all around and I like the thought and work that went into the mounting solution.
This thread has also taught me to now never discuss two things in a forum... Politics OR Mudflap choices. Lol.
I understand both sides, but I'm good with my purchase and others may not be. At least there are options.
Add which is better 2 door or 4 door to that list of non discussions.
Bingo. I have the 6100 black clips too.
For people that are curious, the black clips do not allow the bracket to recess into the flap. The clip length is a hair off and the diameter of the clip thread nub is too wide to go into the flaps pre drilled hole.
Just letting you know that you have the clips on backwards. The nipple(what we call the bumped out part of the clip at Ford) is supposed to be towards the backside, opposite of the flap.
alabamadave
Tuscaloosa, AL
1996 Chevy Silverado
The front flaps are not adjustable, SAS uses a different bracket and flap that is wider to line up with SAS flares. The angle of front and rear can not be adjusted unless you are willing to relax one of the bends on the rear brackets. The front flaps are at 80 degrees, the rear are at about 72 degrees. The bend is circled in the third picture. There is plenty of clearance for the flap tot he rear bumper to straighten it.
Quality reply especially in measuring angles. Thanks! Hopefully they tweak some, at least the front hardware so edge aligns. Thanks again!
BroncoAZ
Mitch
That clip being backwards might make the difference in my front sitting totally square to the truck. The nipple of the clip is hitting the inner fender and may be preventing the bracket from rotating back a little more.
Jjt24
JJ
Toledo Ohio
Escape, Mustang
I don't know about yours, I just know Raptor18 has his clips backwards. I don't have a Bronco to install mine on yet, so I can't really speculate on that.
BroncoAZ
Mitch
Agreed. I don’t think the front flaps would fit well with the nipples backwards.
Raptor18
2020 F-250 Tremor, 2021 Bronco
Thank you! They fit just as good with the bad clips no matter the install.
I’ve reached out to customer service twice now since receiving and not a peep out of them. It’s starting to get annoying.
Inlinejohn
WA
Several
Has anyone tried to install these mudflaps AFTER they did what’s necessary to fit 37s? After 37s mods, were these 2 bolts c/t crash bar joint still intact?
Ford Bronco RokBlokz Mudflaps Review AB0453E5-0A58-4658-A2A8-BC8E1521950A
Marauder
Josh
St Louis
Reading about people spending $200 or $300 or whatever god amount on mud flaps will never cease to amaze me. I'm more than happy to go down to NAPA and buy some cheap rubbers!
I can tell you from experience that cheap rubbers are not the way…
Oh, you were talking about mudflaps?
fltechpilot
Nicholas
Grand Forks ND
2016 Audi S3 1984 Porsche 928S
Are these black clips (part #6100) the correct clips? That's what I received in my shipment but wasn't sure if those were the correct or incorrect ones.
Jjt24
JJ
Toledo Ohio
Escape, Mustang
According to Brook at [email protected] those are the incorrect ones.
Tilzbow
NV
GM Sierra Diesel Pick Up
Wrangler2Bronco
Eastern PA
Wrangler
After months of wait, I finally received my front RokBlokz mud flaps for my Badlands Sasquatch.
This is a preliminary review, in development. In summary, for now it’s a disappointment.
So, for $300 you receive 2 brackets and 2 thin pieces of plastics with dozens of little screws all unmounted. They tell you to use loctite, but it’s neither pre applied nor included. Fine. After you are done playing legos and assemble the whole thing and loctite everything, comes the problems.
The first and main issue is that the flaps rattle a lot as soon as you touch them and on the road (see attached video). They also don’t stay in place properly as there is a lot of play vertically (also shown in the video).
I contacted the support and sent the below video and they replied that the only thing they can think of is to make sure the hand screws are tight.
I fully unmounted the brackets and tightened the hand screws to the point I cut my finger. Still exactly the same issue. On the second video I put way the bracket from the wheel well and you can clearly see the little piece of metal they use is the problem moving up and down.
I replied to them today after doing those tests, and will update here when they reply.
Second issue is the clearance for your tire. Less than an inch at a certain tire angle. The screws on the bracket are already in contact with the wheel wells so can’t really push it more towards the wheel wells. Could be an issue. See picture.
Third issue is the fitment, it doesn’t really sit nicely against the fender flare. That’s mostly esthetic, not a functional issue. See picture.
I have feeling this product has not been tested well (on Sasquatch that is, their website and instruction shows a non Sasquatch with different bracket).
I will update this post once I get any new update from their support. Hopefully they make it right.
I put on ones from sharptruck.com. 350 or so shipped and they come off very easy for off roading. They are only for rock trails and sasquatch package. Lots of bolts to put them in, but happy with them for sure. They look fine and block everything.
Ford Bronco RokBlokz Mudflaps Review 20220418_165138
Ford Bronco RokBlokz Mudflaps Review 20220418_165134
Ford Bronco RokBlokz Mudflaps Review 20220418_165128
M703
2021 Ford Bronco First Edition
I’m happy with mine also. Sturdy, no vibration, and blocks throwing gravel in my driveway.
Ford Bronco RokBlokz Mudflaps Review 6C093816-E012-4D58-BE2B-CB55EE64DC3F
