Rock rail squeaking when I enter/exit
bcrawfo2
Newark, DE
2024 Bronco
My drivers side rock rail squeaks when I step on it to enter exit. Anyone had this? Tighten? Torque spec or just tight?
Lube? Anything else?
crenca
Southern New Mexico
Probably just a tighten. You probably have body mounted steps, OEM I assume (not a rock rail), but more detail and pic would clarify
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
Mine also does it now in the cooler weather, but I chalk it up to off roading dirt and grit. Mine does it on both sides, and I just assume it is grit in the springs. If you also off road yours, try washing the springs off and soaking them with some penetrating oil.
crenca
Southern New Mexico
Springs in a sidestep?
Deadpool392
New Bern, NC
No, the vehicle springs (coilovers, struts, etc.), I am 200 pounds so when I step on them it causes the vehicle to rock slightly. So that’s where I am guessing the sound is coming from.
Bschurr
NY
Snug the bolts up and see if it corrects the squeak.
helifino16
Ron
Mount Sinai, NY (Long Island)
mallaki
Peter
Cary NC
2025 Ford Bronco Raptor
Same issue here on 2025 BRaptor (on top of few other issues...)
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Every time I've had squeaks (springs, suspension and passenger window), it was dust. Take it to a manual car wash or try washing it with a hose and tighten down the nuts. Might try loosening slightly before washing out, then tighten after.
Deadpool392
New Bern, NC
I went to town on all of the bolts on the side steps with some penetrating oil and it has kept the squeaks away. 2 off-roading trips since then as well and it has remained quiet.
bcrawfo2
Newark, DE
2024 Bronco
There is a 13mm inside the front fender. I loosened that just a touch and silicone lubed it and the squeak went away. The squeak came back when I really cranked it down.
