iPhone sync issues
Raceguy388
Grant
My wife’s phone is constantly disconnecting from our 23 raptor bronco. Not really any pattern to the problem mostly random times. Is there in update? Anyone else with this issue? Thanks for the help!!
cptndav
Badlands/Sasquatch
Our 24 Badlands does the same thing. We were excited about finally getting vehicle with CarPlay. I consider myself to be a tech guy but it’s been disappointing so far. The navigation isn’t great either.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Grant, If you’d like further assistance regarding the Sync concern, feel free to send us a private message with your VIN and local Ford dealer. Thank you!
ex_nyer
Chokes
Connecticut
F150, Land Cruiser, Outback
I've noticed similar issues with my 2022 Bronco recently. It randomly disconnects or freezes. The only way I have been able to 'fix' the problem is to stop and turn the vehicle off and then restart.
This seems to be a recent issue, it has generally been very reliable. I'm using an iPhone 13 Pro Max version 17.7
Darth_JoPa
Joshua
Bay Area, CA
2024 Bronco Badlands Sasquatch
FWIW, my android has been doing the same thing ever since the last update on my 2024 Bronco. It sounds like Ford's most recent update has been causing connectivity issues for both Apple and Android users. Hopefully they drop a fix soon
LABadlands
Dan
Los Angeles
2022 Badlands Sasquatch
The only time I have the issue (2022 Badlands/iPhone 15) is when I'm connected to CarPlay and leave the truck with my phone in hand to go back into the house or a store (with someone else in the vehicle, of course). The iPhone disconnects when I leave and when I jump back in an hit the road, it will not reconnect to Carplay unless I pull over, shut down the vehicle, and restart.
Blue Oval
1970 Bronco
To the person that said the navigation is not good either. For some reason I can’t quote the post. I don’t use the Ford navigation. I use google maps.
AlterEgo
2024 Bronco Bandlands Sasquatch
Mine has connectivity issues a lot. It seems to happen when put it in drive before the connection happens (wirelessly). Sometimes I'll leave and it will show that it is connected and the progress bar is moving on Spotify, but nothing is actually playing.
My fix while driving is to hold down the Vol/Power button along with Skip Forward button. Hold both until the Sync system restarts. This has cleared the issue 100% of the time.
That way I do not have stop. Shut it off, open a door then try again.
Mine is a 2024, but may work for your 2022.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
Same here. This happens once in awhile. Also when driving something it just disconnects. Most of the time it reconnects right away. But if it doesn’t a full auto power down is required.
It’s annoying. But doesn’t happen often enough for me to get too worked up about it. I’ve never had perfect CarPlay behavior in other cars. But never maddeningly bad.
Bschurr
NY
I had a similar issue with a new iPhone 16 Pro(iOS 18.0.1) and 23 Raptor. My fix was to delete the device and re-pair and it’s been rock solid since. Sometimes I do need to wait approx 5 to 10 seconds once I power up the vehicle and I don’t touch the phone until the CarPlay button appears on the screen. If I touch the phone before the CarPlay is enabled, it takes even longer…
Jolo86
Orange County
Mercedes GLC 300
Mine does same. You can keep driving and do a hard reset by holding down power button on volume knob and the forward button.
Raceguy388
Grant
I’ve already tried deleting all the phones from the phone list. That didn’t solve the problem
