Rear wiper motor source
zl7cw
Jon
RYRY4646ry
Howdy, My wife has a 2021 Bronco Sport Big Bend and the rear wiper stopped working. If you open the glass on the rear hatch, I can see the motor working, however no wiper. She took it to the dealership and they want $860 to replace the motor - they claim it's binding. But I can't even move the rear wiper manually when the rear hatch glass is open - won't budge. My question is two fold. If I indeed need a new motor, I haven't been able to find one aftermarket - does anyone have a source? $860 for a small motor is NUTS. Also, Is there a trick to get the rear wiper to move manually when the glass is open to see if that's the issue?
Hoping you guys can help!
Tnx,
Jon
VirginiaHeritage
Frank
‘25 Bronco HE
If you can see the motor working, then it’s not the motor. You have a seized wiper arm. I would search YouTube for Bronco rear wiper arm removal for a video showing this, so you can remove, clean and lube the arm where it attaches. Unless the arm is cracked, you may be able to repair this with no parts needed.
zl7cw
Jon
RYRY4646ry
That's what I'm thinking as well. Just wanted another opinion - thanks!
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
Ford Bronco Rear wiper motor source 1786217401335-k4
The arm goes directly on the shaft ,I don`t understand what you are saying about the motor working. Either it works and the shaft (and arm) move or it doesn`t. If it doesn`t you need a motor .
The retail price of the motor is about 185 dollars
zl7cw
Jon
RYRY4646ry
That's not the setup this vehicle has on it. See the pics. The round gizmo is what the motors turns, it goes into the arm assy somehow and moves the wiper. The motor is turning just fine, wiper ain't moving at all.
Ford Bronco Rear wiper motor source bronco1
Ford Bronco Rear wiper motor source bronco2
Ford Bronco Rear wiper motor source bronco3
Pbethel
Patrick
Kingman AZ
2025 Bronco Sasquatch, 2016 Transit 250 148 MR EB
Woud have been easier to help you if you had said Bronco SPORT.
zl7cw
Jon
RYRY4646ry
I apologize for that, it's my wife's vehicle and I'll admit I'm not familiar with all the variations. I drive a '76 F-100 flatbed which I'm replacing a brake line on at the same time I'm messing with this. I'll correct the title of this.
Again, I apologize for the mistake.
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
post your question to the Bronco Sport forum
https://www.broncosportforum.com/
zl7cw
Jon
RYRY4646ry
OK will do - thank you. I'll delete this thread here.
Sorry for the confusion.
VirginiaHeritage
Frank
‘25 Bronco HE
He did say Bronco Sport, first line
Not originally, he added that later. This problem is mentioned on the Sport forums. Sometimes removing the arm, cleaning and lubing it will resolve the problem.
C6ZZGT
Seattle
I didn`t think I read it wrong , glad to see you changed it to Sport. That first picture you can see a mark where the pin has come out of the hole,so if it still doesn`t turn with the motor off the hatch you need a M1PZ17C426A --or try to free it up and it probably seizes again.
