Raptor Tailgate Reinforcement part?
broncorik
Might be able to find online but if you go to a dealership parts center they can usually look up parts and order for you.
Ford Bronco Raptor Tailgate Reinforcement part? Screenshot_20221208_155925_Acrobat for Samsung
Ford Bronco Raptor Tailgate Reinforcement part? Screenshot_20221103-172914_Gmail
Note that the Raptor reinforcement won't fit your OEM carrier unless you notch your carrier (that is why I went with the Hammer Built plate...that and because the Raptor one retails for over 600).
nottinbe
St. Louis, MO
Thank you!
fallguy
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
If you find all the parts and get an install, post it up please. I would probably drop this RC one and go back to my original plan of the stock Raptor one. It just looks better.
broncorik
That vehicle either notched their OEM carrier to fit over the Raptor plate or they have a Raptor carrier with the notch already in it...or spacers. The bolt patterns are the same, it's just that the Raptor plate doesn't span the entire 8 mounting bolt locations for the carrier.
nwGTS
Nate
Chicago, IL
Rick Astley
Up Doug's ass
d
It's been nearly impossible for me tor esearch this topic. Do posts with Raptor content only allow certain users to view them? I consistently am blocked from viewing any raptor content whatsoever.
Yes, this is exactly correct.
If you have said something negative about the Braptor in the past, the admin will have limited your access to that content.
Your participation is greatly appreciated in this completely independent and not at all controlled by say a major American OEM, but nothing negative can be said against the products, hypothetically speaking, of course.
I say this as someone who is also blocked from Braptor content yet still laugh at @Squatch Avatar of Braptor flares every time I see it and he regained his access by, I seem to recall, repenting upon the side tables of Bronco flares along with a large cash contribution to college scholarships.
nwGTS
Nate
Chicago, IL
I KNEW IT! Whose donked Bronco do I need to sacrifice to be in the good graces of our Ford and Savior again?
Rick Astley
Up Doug's ass
d
Put 20's on your Bronco, and 50 auxiliary lights all purchased from vendors then make 17 different threads all asking essentially the same question in slightly different ways. That's a good start.
Or pay to become a level 3 vendor and you can say whatever you like.
nwGTS
Nate
Chicago, IL
Can't do it. That's 4 more lights than my limit. Surely there must be some profile setting I'm missing.
broncorik
You can see the setup Flip went with here...he notched his OEM carrier and added Raptor hinges.
Ford Bronco Raptor Tailgate Reinforcement part? Screenshot_20230117_163815_Chrom
broncorik
Note that the Raptor reinforcement is VERY flimsy. It may look cool to some, but in regard to actually structural rigidity the strength comes primarily from the angled upper and lower bends. The unit is so thin that Flip had to notch his OEM carrier only very slightly. Tyson at Hammer Built has a Raptor in his shop now, and he can share his thoughts if you reach out to him regarding that reinforcement from a fabricator standpoint.
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
it might be flimsy off the truck but is anyone actually bending their gates with a 37 and no other add ons? afaik the raptor reinforcement has survived every full send and has been holding up. it triangulates the hinges to the carrier, and doing so with the dynamic load of the 37 is impressive imo.
broncorik
I believe the Raptor reinforcement with only the Raptor spare is fine...it is when folks start adding other things that they are pushing the structural limits. Some folks are hanging all kinds of stuff off their gates and then wondering why they now have a creak or misalignment...
monsterfd
Ok that makes sense!
