Raptor Headlight Swap
O-BRONCO-O
Jordan
Southern CA
I was interested in swapping my signature LED headlights to the Raptor amber lights. Spent some time searching this before and found conflicting information if they would work or not.
Found a set for a great deal this weekend and went for it. After an easy disassembly of the grill, the lights bolted in without any issues. Everything works great and there are no issues so far.
Loved the added light output from the AlphaRex and Morimoto but couldn’t pass up this set for a fraction of the price.
Ford Bronco Raptor Headlight Swap IMG_3506
SlowPoke
Tom
Connecticut USA
What?
Nice! I wish I had done this before installing my front bumper. I can no longer remove my grille without removing the front bumper first.
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
Removing the bumper is no easy task.. what bumper did you go with?
retrospex
Jay
FL
'23 Wildtrak, Audi RS5 B8.5
that came out great! definitely something I might explore in the future
DirkMtn
Vail, CO
2021 Ford Bronco OBX
I'm looking to do the same with my 2021 OBX. What year is your Badlands? Was it a straight swap plug and play? Nothing needed to reset anything, like needing Forescan?
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
Mine is also a 21. Straight swap! No reset, forscan, etc..!
Dan G
Dan
Fairfax Station
2023 Ford Bronco
Lights look great, would you be able to share the link of where you got the amber light parts? I have a 2022 and like to do the same. Thanks!
O-BRONCO-O
O-BRONCO-O
Jordan
Southern CA
I bought the lights from a braptor owner who replaced them with AlphaRex lights. I don’t have the part numbers. I gotta pull them off to get the part number
Chapito
Laredo, TX
2023 Bronco Wildtrak
I’m interested in this swap would anyone know what the part numbers are for the raptor headlights?
wtsas
Omar
tupelo, ms
2024 Ford bronco
Ford Bronco Raptor Headlight Swap IMG_4010
that’s my next mod
Darcyjs14
D’Arcy
Seattle
1970 Ford F250 Camper Special 4spd
The parts counter ninja at your local Ford store can find the most current set of PNs for Braptor lights that should work in your truck. I plugged in my (braptor) VIN and this is what came up
https://parts.lakelandford.com/a/Fo.../Front-lamps-Headlamp-components/ML21028.html
oddly enough, i can only find the R headlamp assy, but the left exists. I just can't get any of the end-user parts portals to cough up the info. The parts counter guys have access to much more detailed systems and will be able to get you what you are looking for.
that said, there appear to be a handful of iterations of this Braptor headlight, so working with eg @flip is your best bet to making sure the part you buy works in your truck.
Ducati1098
oddly enough, i can only find the R headlamp assy, but the left exists. I just can get any of the end-user parts portals to cough up the info. The parts counter guys have access to much more detailed systems and will be able to get you what you are looking for.
P2DZ-13008-D and P2DZ-13008-F are the newest part numbers.
Darcyjs14
D’Arcy
Seattle
Thanks @flip, appreciate the current PNs
