OEM base bumper to Raptor bumper swap, Auto Headlight function not working.
OrlandoBadlands
Corey
Orlando, FL
2025 Bronco Badlands
I just took off our factory base bumper with fog lights.
Installed a modular bumper with the rigid fogs on upfitter switches.
I had to unplug the old fog light harness and put it to the as I didn’t want to use it.
Why will my auto headlight function not work anymore? I have to manually switch them on now.
Any help is appreciated
Thank you.
WillinMA
Will
Groton, MA
2021 Wildtrak, 2025 BRaptor, 2025 G63, 2020 Lambo Huracan Spyder
I know folks say the auto high beam works off the camera in the windshield, but maybe check you reconnected the front camera wire and washer fluid hose on the passenger side - if you took off your grille, you would have had to undo those 2 lines before taking off the grille
