Raptor Headlight Module Part?
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
I agree.
do you know if the wiring is the same to the light between raptors and non raptors? My diagram book is only 2021.
i think my next step is to put a raptor vin in the BCM and redo the lighting procedure in hopes it might pull a different procedure.
Ducati1098
I agree.
Yes all wiring is the same. Doesn’t show anything Raptor specific in the wiring diagram.
Bigmoose
Bigmoose
Jon
RI
Im going to have to give up for now. I attempted to load a raptor vin in the BCM and rerun the exterior lighting procedure in FDRS without any luck.
Whats really annoying is after running the LIN BCM procedure my known good headlight stopped working.
it seems clear the headlight module is not programmed correctly. If i flash my high beams the orange DRLs illuminate. Low beams work fine. No working blink function.
i currently have a set of base headlights installed that are working fine.
BroncoBen4x4
Ben
Marne Michigan
2022 Ford Bronco Wildtrak
I am experiencing the same exact problems with my raptor headlights in my wild trak. Did you find a solution to the problem?
Ford Bronco Raptor Headlight Module Part? 1000000333
Bigmoose
Bigmoose
Jon
RI
I did fix mine but it required put them into a Raptor and running an FDRS procedure.
BroncoBen4x4
Ben
Marne Michigan
What did you use to do the first. Procedure? I will have to find someone local willing to help me out. Thanks for answering me so quickly.
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
You need to find a Raptor to install the lights into, then run the Enhanced Exterior Lighting procedure for the BCM in FDRS.
