Headlight/Tailight Flasher Module
KyleNL
Kyle
St. John's, Newfoundland
This looks awesome. Was there enough room on the footwell kick panel for the harness? Assuming it’s like the one I had in my F150. That was a nightmare to tuck and fit. Also, which switch number did you end up using to activate these awesome lights?
It was very tight. That was the hardest part, had to bend the wires to make it squeeze in there and i was getting past my comfort zone doing it. You can kind of see in these pictures. (sorry for the blurry one).Going to go back in this weekend and try and clean up the wiring. I don't have the aux switches. Hold the high beams for 3 secs or press a button that came with it for 3 secs.
Ford Bronco Headlight/Tailight Flasher Module 20251015_105133
Ford Bronco Headlight/Tailight Flasher Module 20251015_111739
Ford Bronco Headlight/Tailight Flasher Module 20251015_111754
KyleNL
Kyle
I did the same. VERY HAPPY with the results....
Lol, I've been looking for videos of them on the bronco's for months. Where the hell you been??? :ROFLMAO:
Looks Good!
Honkman
J
Tennessee
2023 Bronco, Outer Banks, 4 Door
I finally bit the bullet and did it. Took 15 mins in my driveway in the dark with a flash light. 8 different patterns. You can shut high beam/ low beam and reverse lights off. Which is good since they are blinding at night. Lol
This came out amazing! Awesome work!
Did you get it from SpeedTech or UltraBrightLightz?
Thanks
rayofsi
Staten Island, NY
Raptor Gen2
curious, has anyone had any gremlins with the zflash?
i have cases where my rear running lights do not turn on,
brake, turn and backup work fine. but rear running lights stay off until i manually reactivate then with the headlight switch.
KyleNL
Kyle
Nothing at all on my 21 outer banks. Are they Led or halogen tail lights?
KyleNL
Kyle
Although I didn't notice you have a raptor....... I did have issues when I installed them on my bosses 2024 Raptor. I did the same as the installation on my 21 OBX but when I reconnected the battery the parking brake light came on and said parking brake needs service and would not go away after multiple test drives and hours sitting. Was ready to unhook it and take it to Ford and play stupid but On my 3rd attempt reinstalling it, I left the truck for the night with it installed and it did go away the next morning on start up. But the raptor definitely reacted differently then mine did. So maybe there is a difference in the 2 BCM's 🤷‍♂️
rayofsi
Staten Island, NY
Raptor Gen2
Thanks. will probably remove it soon and see what happens .
