Raptor Headlight Module Part?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
So i just had one of my raptor headlights on my badlands go out. Come to find out there was a small crack at the electrical connector. This allowed water to get in during a long drive in heavy rain. Of course the control module is at the bottom so guess where all the water ended up…
Can anyone verify that the part in the picture is orderable part LC5Z13C788I?
@flip
Ford Bronco Raptor Headlight Module Part? IMG_8754
Ducati1098
ML3Z-13C788-A
Looks like there’s plenty available.
Not sure where you got that LC5Z number from though.
Ford Bronco Raptor Headlight Module Part? IMG_5048
Bigmoose
Bigmoose
Jon
RI
Awesome. Thanks a bunch.
@Ducati1098 I got that number by looking up a parts diagram for a 22 braptor on tascaparts.
Ducati1098
Oh okay. Yeah that number shows for 22-23
The ML3Z is for 23 and up. Not sure if they’d both work, but your picture is the ML3Z module.
Ford Bronco Raptor Headlight Module Part? IMG_5049
Bigmoose
Bigmoose
Jon
RI
@flip @Ducati1098 I got my new headlight controller in. Parts match. Its not behaving properly. The behavior follows the module if I switch it between headlights. Do these modules need to be programmed?
Bigmoose
Bigmoose
Jon
RI
I should add that i did a BCM LIN initialization and now neither headlight seems to work as expected. Low beams work, but no blinker or signature lightning.
its like the configuration is wrong. High beams turn on the signature lights.
Ducati1098
I thought I remember seeing some other headlight configuration program in FDRS that is supposed to be run when replacing either the module or the headlamp assembly. I don’t have time right now to look in FDRS, but I will a little later tonight.
Bigmoose
Bigmoose
Jon
RI
I ran both the BCM LIN calibration and Enhanced Exterior lighting calibration. Neither fixed the problem.
Ducati1098
Oh okay. Yeah that’s the other thing I was referring to. Do you have any DTCs present?
Bigmoose
Bigmoose
Jon
RI
The BMC was reporting turn signal short/open circuit. What is weird is one light worked totally fine until i ran the LIN procedure. Im wondering if the fact these are raptor lights is causing this. Do the white signature headlights us the same module?
Ducati1098
Yeah that is odd.
Regular Broncos built after 5/17/22 use the same ML3Z-13C788-A
Before that the Raptor and regular Broncos were different.
Bigmoose
Bigmoose
Jon
RI
My blend date was 08/01/22 so its has the correct module. Hmm.
Ducati1098
There are 2 headlight fuses in the battery junction box. I believe 20 amps in spots F100 and F101. Check those, I had a somewhat similar issue with a Bronco getting water in the module from a cracked headlight after a collision.
Ford Bronco Raptor Headlight Module Part? IMG_5188
Bigmoose
Bigmoose
Jon
RI
Funny enough both of mine were blown (from swapping the bad module around) but I replaced them prior to using FDRS
Ducati1098
Yeah I’m not sure then. It’s gotta be some type of programming related issue.
