Raptor button not working
Derrick
Derrick
Ontario, Canada
2023 Bronco Raptor, 2010 Audi R8 V10
Last few days notice the "R" button not working and did some research and some say to wait a day and check , but still not working. Found same issue on F150 Raptor forms and they say to disconnect the negative battery terminal for 10 to 15 minutes. Disconnected mine for an hour while I was doing other things then re attached and now is working. I didn't see any updates so not sure why this happens and first time since I picked it up 10 months ago.
swamp2
I posted on this very topic not too long ago here on the forum. The solution is indeed battery disconnect.
Derrick
Derrick
Derrick
Ontario, Canada
Thanks, I did a quick search before posting but nothing popped up. Maybe I am using an incorrect phrase or something.
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Search functions on forums generally suck..
Next time, ask google.. but add *insert forum name here* at the end of the question or whatever. You'll find it works much better.
swamp2
Google-fu tip of the day to supplement/clarify this. This is generically applicable and I use it constantly. Try this syntax:
your search terms site:website.com
For example:
R button not working site:bronco6g.com
results in the first hit as my post.
Thank me later ;-)
Kjbeggs
Kelly
2019 Ford Ranger
I find most times, just a standard Google search for any Bronco related question leads me to B6G for the answer anyway!
PA BRaptor
Kevin
Western PA
Ford F350
I've had mine for just over 1 year and about one month after purchasing it Raptor button quit working. I disconnected the battery and left it for 20-30 min. After reconnecting it all was fine, it worked. It never happened again.
Johnny Mo
Westchester County, NY
teachu2shoot.com
Love this place! Mine started acting up, came to the forums, found this thread, disconnected the neg terminal, wait 20 min, all is right with my Braptor again. Thanks gang!
PatagoniaDan
Georgia
Mine just went out past couple days also. I waited two days and it magically came back on. Not kidding. I'd give it a couple days and if still not working try the negative battery terminal disconnect.
DewarT
Todd
I've seen these posts a number of times... and now its happened to my '23. Last night leaving work and verified again this morning.
A simple fix here, but a bigger concern to me is the entirety of the electronics systems.
My Mabett interior lights stay on randomly for extended times- OK that's aftermarket, but still runs on factory power which should have shut off
Odd transmission shifting- really random quirky stuff under normal driving conditions that doesn't repeat often, but still seems to be computer related. Sport Mode has its issues, but this is in 'normal' mode as well.
The Stereo frequently does not connect immediately to Sirius- or is really slow to connect- even in good service areas.
Phone connection issues
Phone charger overheating my phone
Cam Phaser issues- which I have not experienced...
Battery issues
Etc, Etc
I love this Raptor, but I feel this impending sense of doom with the electronics.
