Raptor Transmission
crimsonhokie
Knoxville
'07 Civic Si, '17 Ducati Supersport S
Is there any info out there regarding which transmission will be in the Raptor? I know there’s been a lot of comments in terms of increasing power from the 2.7 given the limitations of the 10R60. With the increased power and torque from the 3.0 combined with the higher tow rating, I’d like to think there’s been some modifications/changes to the transmission but haven’t see anything mention it.
TurboS
2022 Bronco Raptor, 2023 Bronco Badlands
I thought I heard in one of the video's that the 10R60 had been modified for the Bronco Raptor.
BR0NCO
Randy
Mass
Jeep Audi
I think the T case was, not the transmission
vrtical
Doug AI
GSMNP, TN
Fords
I could see upgraded clutch pack. tcase for sure have to wait for part nbrs
Sstockss
Indianapolis
2020 Ford Explorer st
I have done a bit of drivetrain testing with the 10r60 drivetrain, and didn't have any problems in over 50k miles.
JohnGalt
Tahoe, CA
2023 Defender 110
Motor Trend should be fairly accurate. And reputable source.
“Upstream of all this, the transfer case gets a stronger clutch for 4A automatic on-demand engagement, but it carries over the 3.06:1 low-range ratio and overall 67.8:1 crawl ratio. The standard 10-speed automatic is unchanged but for a revised torque converter and the addition of a second transmission oil cooler.”
Full article:
https://www.motortrend.com/news/2022-ford-bronco-raptor-engine-driveline-details-specs/
