random check engine and reduced power
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I got a check engine light the other day and it went into reduced power mode. I pulled over and shut it off, restarted and was able to get home ok. I checked for codes and found nothing..... Anyone else have a similar experience??
stevenstommyboy1
Thomas
Menasha Wisconsin
2023 Bronco Raptor
Strange occurrence. Any unusual stress on the engine, high heat driving or off road use. Fluids good? Sometimes will not throw a code until the next occurrence. Hope it reveals it self.
Valhalla
Valhalla
Chattanooga Tn
What Ducati said, if the CEL clears you have to have a reader that reads the stored codes.
raptorusmaximus
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
Whatever you’re using to pull codes likely isn’t good enough. Send me your VIN and I’ll check connected data
I PMed you the VIN.
I checked both an SCT programmer and my whipple tomahawk v2, neither one could find a code....
I checked with my dealer and they want to check the wiring harness for corrosion.
Felix808
SRV CA
I PMed you the VIN.
I have found that the Tomahawk will miss a lot of codes as well as not be able to clear them such as ForScan can. GLWTF 🤠.
Found out the same with the ProCal scanner - it only looks at the PCM, and everything else it more or less just pretends doesn't exist.
Dan-O
Dan
Fountain Hills, AZ
Aggravating…….I've been getting 4x4/powertrain fault about every 30 days like clockwork, only when starting engine….doesn’t go into limp mode or prevent goat modes, lockers or any other powertrain functions. Turn off engine and start it back up faults gone and doesn’t do it again for about another 30 days. Tried the whole trickle charger idea and doesn’t make a difference. No codes… Service advisor says they’ll need to keep it for a few days as the troubleshooting procedure is fairly in depth module testing??
Hope you get it fixed as painless as possible.
Yeti'sBronco
Sturbridge, MA
2023 Ford Bronco
I have received this Powertrain Malfunction / Reduced Power service soon warning four times now, always paired with Pre-Collision assist not available.
These started when mice chewed through wiring to cyl 2 & 3.
Each subsequent time, there has been no impact on performance.
When I cycle power, the warning goes away.
Every time, dealer finds nothing.
How / where can I find wiring diagrams to trace how oddly paired error codes may be connected?
23 Outer Banks, 2.3 L
CalvinT
Calvin
Phoenix, AZ
Wiring diagrams won't give you error codes. But the Powertrain Control Module is probably involved in Pre-Collision assist since it probaby cuts back on throttle. It probably threw the code when it couldn't control the engine.
The dealer isn't finding anything because the cause is gone once you fixed the wiring.
Yeti'sBronco
Sturbridge, MA
2023 Ford Bronco
Thank you.
I've downloaded the service manual & found the details I wanted,
Now on to try to troubleshoot wiring issues
jrb1
J.R.
Maine
www.jrballphoto.com
'22 Bronco 2-Door Base Sasquatch & '06 Jeep Wrangler
Thankful this thread and forum exist...
I just had the same issue on my '22 basequatch w/ 45K miles. I used the forum to diagnose the issue and ended up replacing my OEM battery -- the most likely culprit -- based on overnight voltage loss.
I reset the battery management system and let it rest overnight. It seems to have resolved the issue...for now. :LOL:
