Check Engine Light Warning - Powertrain Malfunction / Reduced Power
Ajsbronco
AJ
PA
2021 Bronco 4 Door Outer Banks SAS
On my way into work this morning and all of a sudden thud, low power and shifting was weird. Had the car running 10 minutes before I leave every morning to warm up because of how cold it’s been. Got into work and won’t go into reverse. Any other people have this issue?? Have the 2.7
lasttj
Robert
'06 Jeep TJ, '16 Ford F150, '65 VW Beetle
Do you have a scanner so you can check for OBD II codes? But, obviously, you need to take it to your dealer.
ZipZit
Zip
Las Vegas NV
2020 Escape, 2008 Mazda3
ELM style scanners are very inexpensive. Link that wirelessly to a free app on your mobile phone. Do note, be careful to purchase a scanner that works with your phone type (iPhone = Bluetooth LE, Android = Bluetooth).
Helpful link. https://www.obdadvisor.com/elm327/
I recommend the App “Car Scanner” or “FORScan Viewer”. Both are free, FORScan Viewer just works on Ford/Mazda and offers a bit more info then just basic Engine / Fuel report out.
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
That happened to me...it was one of the turbo pipes that came loose.
I posted this awhile back...although mine was around 65-70 mph ..weird shifting (which I think is just part of low power mode /limp mode) I don’t remember having problems with reverse.
if you have the Ford App it may tell you more about the fault code
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Ford Bronco Check Engine Light Warning - Powertrain Malfunction / Reduced Power ED5C8610-DD8F-41F0-BC49-EB9D9EF971E8
Hello, AJ!
Send us a private message with your VIN and the name and location of your local Ford dealer.
I’d be happy to see what I can do to assist with this Powertrain Malfunction concern. Thanks!
NotApplicable
BEVs
8k miles is near end of life on the 2.7
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
It didn't cause your engine failure but 10 minutes to warm up your vehicle is unnecessary. 60-90 seconds is all a vehicle needs to begin gently driving to achieve operating temps.
Winni Made
Gilford, NH
2016 4Runner
I did. My issues was related to an issue I had shifting to 4L and it got stuck in 4L (there is another thread on this). Had it towed to the dealer, they clear the error codes and seems to be fine now.
BigHoof
PA
Ram 2500
I'd like to see a window unfog in 60-90 sec with no engine heat.
710-oil-614
Cal
Columbus, Ohio
Interesting. My windows don't fog until I would get into the vehicle. I just crack my window and that generally alleviates the issue.
But 10 minutes probably lets your car warm up so you're comfortable once you get inside.
Geo
Geo
Ford Mustang
Hello, AJ!
Just had the same thing occur. 2.3 manual transmission. 1200 miles.
blanchardsbronco
Keith
Spring, Tx
ford fusion
ahhhh hoping I was immune to this. My 2.7 did the same thing last night. Luckily I got it home. Coughing, sputtering, conking out on me...... not fun!!! Working on getting it towed to the dealer now!!!!!
Ajsbronco
Ajsbronco
AJ
PA
Dealer fixed it that day. They only had it for 2 hours. It is a known issue, under the passenger footwell there is a connection peice that is known to be put on wrong. Running great since that
