Radiator cleaning questions (2.3L)
Fillups
Geoff
Cincinnati
2022 Bronco, 2010 Expedition EL
My 2022 2.3L was running too warm on a recent road trip, especially on the uphill climbs. Most of my daily driving is local, 40 mph stuff, and it seems fine at those speeds, short drives.
We did some muddy trails this Spring, and I rinsed it well, but probably not well enough. Wondering if anyone has had success with the Radiator Genie wands? And should I be pre-treating with a cleaner like for AC condenser coils? The attached pic is something available at Lowe's.
Thx!
Ford Bronco Radiator cleaning questions (2.3L) PXL_20260805_182134381.MP
Desert_Brush
SoCal
2015 Mini Cooper
What temps were you seeing and how was the weather?
Fillups
Fillups
Geoff
Cincinnati
On the flats we were running 210 to 215, but on longer climbs we crossed 230 several times and got the "reduced power" message on the dash once. This was on Northeast TN, afternoon temps were in the mid-80's.
Manual transmission, and I always to keep the tach at 2k or above on hills, so usually 5th gear uphill on the highway, 6th gear on flats runs.
CalvinT
Calvin
Phoenix, AZ
Thx!
To me it looks like a solution in search of a problem. I've never needed such a product on any car I've owned. All were Arizona cars.
Desert_Brush
SoCal
2015 Mini Cooper
But he has a problem. Overheating possibly due to mud in the radiator fins.
Fillups
Fillups
Geoff
Cincinnati
[/QUOTE
Here in Southern OH and central KY, mud and deep-ish water is unavailable on our trails. This type of mud is probably not ab AZ issue.
I've never lost an alternator like many with 2.7's have on the same rides, but it's fairly deep. And the fans run and slings it up even higher unfortunately. So I know I need a more thorough cleaning.
CalvinT
Calvin
Phoenix, AZ
I've just used a garden hose with a spray nozzle with nylon brush to clean a radiator or condenser. Maybe with an attachment that lets you apply Simple Green or something similar.
I don't think an aerosol can will work on mud build up. Those products are intended for an A/C tech to carry in his tool kit when working on a building's A/C.
RedBeardoh
WA
2019 Ford Ranger
Idk how your Bronco is set up, but mine being a manual Sasquatch I don’t ever climb a hill below 3k. At 2k on flat ground mine seems starved of power and really likes being above 2600. I wonder if staying out of boost while in a climb could be contributing to your heat gain?
Fillups
Fillups
Geoff
Cincinnati
That's a fair point - higher RPM may help, but I think only marginally. I have the split gauge with boost up on the dash all the time. I have noticed as long as I'm above 2K on flat or smaller hills, the 2.3 builds boost to hold or accelerate without downshift. Steeper hills, that threshold is more like 2500 RPM. So I don't think it's lugging, but can try a higher RPM range.
But my driving style hasn't changed and engine temp was not an issue before the muddy trails. I'm gonna remove the plastic cap behind the grill to see if more thorough rinsing helps.
brkdncr
Southern California
Toyota 86
Pics of your radiator would help. A hose should be all you need.
the temp you see on the gauge is oil or trans temp, not the water temp. Temp is a more typical gauge under the speedo.
running low rpms under load could also mean high turbo boost for extended periods, which can really bring up temps.
is the rad the same for both the 2.3 and 2.7? My 2.7 occasionally sees high oil temps but water has stayed right in the middle.
I’ve also noticed that if my oil temp is warm, turning the a/c on drops the oil temps really quick.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
Also, according to people who know a lot more than me (e.g. Ducati) the oil temp gauge is an "inferred" reading, meaning there is not actually an oil temp sensor. Not sure how the Bronco infers the temperature, but given that I'm also not sure how accurate it is.
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
i usually don’t let it make more than 4-5 psi of boost in 5th gear. any more “load” than that and i’ll drop to 4th. ecoboosts used to be notorious for low speed pre ignition issues, makes engines go pop lol. its why the early fiesta / focus ST tunes got nicknamed “ecobooms”
Pbethel
Patrick
Kingman AZ
2025 Bronco Sasquatch, 2016 Transit 250 148 MR EB
Coil cleaner is really aimed at organic debris/dirt. Hair, grease, pollen, household dust. Get the mud out first and then maybe.
Most are acid base but evidently not PF.
Fillups
Fillups
Geoff
Cincinnati
Yeah, I was watching the oil temp since it displays a number to monitor. But that's a good reminder that is likely not the temp that triggers the alarm. I didn't know the oil temp is inferred, interesting. I didn't even pay attn to the bar graph temp in the moment. Also wouldn't have thought turning on AC would help oil temps.
Is there a way to see coolant temp number on the gauge cluster? I have not found it poking around yet.
