Do You Know What Makes a Radiator So Important? - Mishimoto
Status
Not open for further replies.
Mishimoto
Garnet Valley, PA
F-250
What makes a good radiator? Do I need a radiator? At Mishimoto, radiators are at the core of what we do, and one of the most common questions we hear is: “My temps are creeping up… should I just go bigger?” A performance aluminum radiator can absolutely improve cooling by increasing heat dissipation, durability, and consistency under load—especially compared to stock units with plastic end tanks. But here’s the catch: bigger isn’t always better. That’s because cooling depends on the entire system—airflow through the grille, fan performance, and core design, such as tube size, fin density, and row configuration—not just on size alone. There’s no one-size-fits-all solution either; what works for a daily driver may not work for a track car or a tow rig. Choosing the right radiator comes down to matching the design to how the vehicle is used. To dive deeper into what makes a good radiator, check out one of our latest blogs:
https://www.mishimoto.com/engineeri...-core-thickness-tube-design-airflow-explained
Also, don't miss your chance to win a FREE radiator of your choosing. Enter to win below!
https://www.mishimoto.com/aluminum-radiator-giveaway-april-2026
Ford Bronco Do You Know What Makes a Radiator So Important? - Mishimoto Radiator_Blog-7
Valhalla
Valhalla
Chattanooga Tn
Could just need cleaned
KTM300
Dallas Texas
2024 bronco raptor
Is it made of plastic like the one Ford uses?
Valhalla
Valhalla
Chattanooga Tn
High radiation plastic thank you!! needs a brush guard or... well you know...
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
@KTM300 No, our performance aluminum radiators offer a significant upgrade over the factory crimped plastic rads that become brittle and crack over time.
@Valhalla you're cleaning your radiator?
Sir915
Shawn
El paso
2023 Bronco
You have any options for the bronco raptor?
Sir915
Shawn
El paso
2023 Bronco
Don't see any options still ......
Valhalla
Valhalla
Chattanooga Tn
yes, just low-pressure open hood back flow, it is muddy in east TN, years of wheeling has taught me this.
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
That’s because cooling depends on the entire system—airflow through the grille, fan performance, and core design like tube size, fin density, and row configuration—not just size alone.
... all good BUT doesn't help if the Thermostat is 200* controlling inbound flow to the engine.
Ford's OEM is good but emissions require a hotter Thermostat ... lower it too much and now you need to return the ECU
Mishimoto
Mishimoto
Garnet Valley, PA
F-250
Right now we're developing an intercooler kit for the Bronco Raptor which is slated to release this fall. A radiator is also on our list but we don't have a set release date just yet. We'll update you here when we know more!
BigMeatsBronco
Allan
2021 FE 2 door
I have your F 150 transmission cooler on my V8 swapped bronco and can confirm your aluminum products are FAR superior to OEM plastic!!! Im SO pleased with your products, I also just ordered your aluminum coolant tank replacement for the Bronco. The original OEM plastic developed a crack and a leak that was difficult to diagnose. Thanks for your support of all the vehicles!!!
joes bronco
Gordon
post falls Idaho
2021 bronco 2017 f150
Really want to know what makes a good radiator great ?? First remove the shutters then but a big 16in pusher fan in front of the radiator connected to a upfitter switch big difference
Status
