Problem with auto-on headlights
FordFamily4Fun
Kyle
Augusta, GA
'10 Escape, '16 Explorer, '22 Bronco 2-door
Just bought a used BD. The base (non-Signature) LED headlights. As everyone knows there is a dial to the left of the steering wheel to set parking/auto-on/always on headlights. I have it set to auto-on and you get the amber light next to the switch turned to auto-on. This works just fine as I am out and about. Leave the BD to shop and come back and the amber light is set next to auto-on. However, when I start my BD in the morning there is no amber light next to auto-on or any of the light settings, and my headlights are on. This pretty much defeats the point of auto-on at dusk or rain. Any thoughts? Thankfully still under warranty if need be.
HeliPilot
Kenny
CT
2022 2.7L SAS
If you are remote starting it, nothing will be on until you hit the start button
Idaho Driver
Bruce
2021 Bronco, 2011 Raptor
There is a problem with the headlight switch and you can get it changed under warranty. Mine would change positions and sometimes the lights would come on unattended.
I started a thread on here and a Ford tech contacted me to diagnose, then I took it to my dealer for the warranty replacement.
Robs
New hampshire
2023 Black Diamond
I read a previous post and have experienced it myself when getting into or out of the BD my knee accidentally rubbed up against the light knob changing the knobs position. The only glitch in the system was me
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
All of this computerized shit make me put whiskey on my cornflakes.
Why can't Form keep it simple?
Uhdinator
Iowa
Ford Bronco
check your settings menus. Mine is set to Auto mode when the vehicle is started.
To access the headlight settings on a Ford Bronco, navigate to the vehicle settings menu on the infotainment system, typically labeled as "Vehicle" or "Lighting," where you can adjust options like automatic headlights, daytime running lights, fog lights, and even automatic high beam functionality depending on your Bronco model
