Disabling Auto Headlights
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
The "auto" headlights I find are irritating. Lights come on every time I just open a door or unlock the vehicle. High beams go on and off on my very early AM commute, I have to manually flick the lever to get them to stop- every day.
Then on top of that mine has the issue of the lights just coming on randomly or not turning off. It's got to do with the passenger door and when I open it with the vehicle off and parked it messes up the lights. Then when I open the drivers door to get in after the chimes come on- ugh such a pain. I have to manually turn the dial to turn the lights off to get rid of the chimes and just resets every time. From reading some other posts on the subject I believe I have a defective headlight switch. But so hard to get it in to the dealer working, working, working......and my spouse working even more. I do my own maintenance so defects are tough to bring it in to Ford.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
As mentioned, if you are looking to stop the Bronco from automatically choosing auto headlights every time you start, you need Forscan. You can set it to always select the last position your headlights were in, like a normal vehicle. ;)
quipstad
Ben
Eastern WV
2022 Bronco 4DR 7MT 4A, 2013 Outback 2.5L 6MT
Can anybody tell me which Forscan module and function need to be changed
BdyCM 726-74-01
xx** | xxxx | xx--
Changing only the asterisk characters from 00 to 01 will prevent reset to auto; it will retain the last selected position.
HeadlampPosAtIgnOn_Cfg: 00=Auto 01=Last Known
vincent chiang
taiwan
ford
THANKS A LOT
It,s that (HeadlampPosAtIgnOn_Cfg: 00=Auto 01=Last Known )in the BCM module
I want to know what moudle will been changed not the asbuilt
thanks
BdyCM 726-74-01
xx** | xxxx | xx--
Deleted User 5719102
Who's
On a Lake
22 2dr
I disabled mine with SuperChips FlashCal. This way I can change back if I choose with the handheld.
BadsquatchNV
Cori
High Desert NV
18 Jeep Rubicon Recon JK; 24 Ford Bronco Badlands
Is there a way to disable the reset to auto lights at each start in the 2024 Broncos… or does it still require Forscan?
I turned off auto high beam and daytime running lamps. Still resets to auto at start.
BSBAGR
Christiansburg, VA
F-150 FX4
You can switch the headlight switch from always auto on startup to last position on startup using Forscan. It is a plaintext selectable option in the BCM.
Hello,
I looked in Forscan and couldn't locate " BCM " Any chance you could tell me what it is listed under?
I have a 2024 BD Sasquatch 2 door.
Thanks and I hope your Holidays were great.
Imsomaha
Omaha
2023 ford bronco
Where is that option in forscan
cbrenthus
Western PA
I honestly can't remember, its been a long time since I was in there. Somewhere on this forum is an excel doc with all the Forscan settings, that's where I would have gotten it from.
Imsomaha
Omaha
2023 ford bronco
Thanks. Yeah ive seen it before but been awhile. My lights keep turning on after engine off. Changed switch reset bcm bms etc. still happening. Just ordered bms sensor at neg battery, gonna try that next. Any suggestions. Dealership said accessories are drawing to much power but dont beleive them, they suck. All accessories have been removed from battery
BroncoChallenger
2024 Bronco
Good. I'm getting sick of all the dipshits who can't figure out how to turn their headlights on.
Biggest pet peeve of mine, people driving in low-light situations with their headlights off. See it quite often in the winter on my way home, or in the morning during summer - twilight, dark road, all of a sudden there's a vehicle there I didn't see because the guy didn't have lights on. The auto setting is there so that doesn't happen.
Personally, I'd rather see the switch go away completely, so the lights are ALWAYS auto-on...and if you need them off (pulling into your driveway late at night trying not to wake your spouse up) you've got to push and HOLD a button to keep them off.
