billiam
Washington
2023 2D Black Diamond
Alight - so I did a 2" level lift, got it realigned and put the Micky Thompsons on. have about 7k miles and I'm seeing heavy treadwear on the outside of both front tires. I'm guessing they screwed up the alignment.
Valhalla
Valhalla
Chattanooga Tn
Pucks may be forcing the A arms down to achieve lift.
billiam
Washington
hmm, so new upper control arms? Taking it in to get the alignment looked at Wednesday. Will see what that show...
AARDVARK122
john
utah
2007 volvo xc70
I have a 2” puck level lift on mine. I have 25k miles on my Mickey Thompson tires and they are wearing perfectly. I am guessing they messed up your alignment.
billiam
Washington
Alignment was hosed. Looks like the shop didn't do anything. Nearly toasted the front MT's - glad I didn't rotate them, only lost two.
AARDVARK122
john
utah
2007 volvo xc70
That sucks donkey chunks. Sorry dude.
PorpoiseBlue
Mercedes, TX
Ram 1500 Laramine
I am interested in putting pizza cutters on my stock sasquatch bronco. I like the look of the 255/85R17 Mickey Thompsons, but after doing some research, I am starting to doubt they will fit the stock sasquatch wheels. Does anyone know if there would be any issues?
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
What makes you think they won't fit the OEM Sasquatch wheels?
Ford Bronco Pizza Cutters - Show Yours! 1780479086741-e7
FoCoBronc
Colorado Springs
‘26 BL - previous ‘22 OBX, Tacoma, X3, MDX, Bronco II
I thought SAS rims are 8.5"? I'm contemplating some form of Pizza Cutters myself and wondering what narrow width high profile tires work well on 8.5-9" rims. Googled this issue and looked like some narrow tires with high profile run risk of breaking bead lock on truck/SUV, but maybe that is serious off roading risk....
GI_Jo_Nathan
Jonathan
Under reasonable conditions you shouldn't have to worry about that unless you're going to single digit pressures. If you keep 12 or above you should be fine. Unless you end up in a bad situation with a lot of pressure on the bead specifically.
Other than that the tread just may be a little narrow looking for the width of the wheel. Especially with the Sasquatch Wheels having the trim ring making it wider than it really is.
Straightbase
Massachusetts
2 door Base MT
While I agree with you 100% , I've also learned to just let it go ... let them run with it.
In the mean time , I'll continue to wish for the return of the 33 x 9.5 BFG AT they had out for awhile. LOL
In other news, I'd like to see the "pizza cutters" on the 16" Base wheel.
I think the 255/85-16 is probably the reigning king .... unless you go with the old military tire ... 255/100-16
LOL!
LOL!
Ford Bronco Pizza Cutters - Show Yours! 1749613724996-j5
Ford Bronco Pizza Cutters - Show Yours! 1749613759790-
22 Base with Yokohama Geolander M/T LT255 85 R16
Ford Bronco Pizza Cutters - Show Yours! IMG_0105
Ford Bronco Pizza Cutters - Show Yours! IMG_0229
Ford Bronco Pizza Cutters - Show Yours! IMG_0230
PorpoiseBlue
Mercedes, TX
Ram 1500 Laramine
The Sas wheels are 8.5 which has me concerned. It doesn't really seem like anyone has mounted these tires on the stock sas wheels.
Found this on an FJ Cruiser Forum. Maybe it'll be fine?
Ford Bronco Pizza Cutters - Show Yours! Screenshot_20260603-093339_Firefox
dgorsett
colorado
F250, Mustang, Explorer
I'm sure they'll work, if a shop will mount them. They might look funny. I had two vehicles with 235 tires on 8" rim and they looked a little odd.
Fordified1
Bob
Mid South Texas
The taller the tire, the more leeway you have in rim width because of lots of sidewall.
PorpoiseBlue
Mercedes, TX
Ram 1500 Laramine
I know a lot of people put Kenda 35x10.5R17 on the Sasquatch broncos. I never used their tires before so I am hesitant to. But I'm sure theyre fine.
I did find that Toyo makes the AT3 in the same size, 35x10.5. None of the places local to me carry them but I'm gonna try ordering a set.
