part number for oem subwoofer?
pizzy
larry
Pa
2023 bronco base
Does anyone know what the part number is for the factory oem subwoofer?
Montana Bronco
Montana
Chevy
If you want mine you can have it for free.
I put in the JL Subwoofer and amp. Sounds great.
Ducati1098
M2DZ-18808-L is the newest part number.
pizzy
pizzy
larry
Pa
2023 bronco base
Wow. yes please. I would like to have it so I can put my system back the way it was supposed to come. Mine came with the subwoofer delete Just need the speaker not the housing Please let me know what you need for compensation for shipping or simply your time
Larry
Fly by Nite
Walt
Pa
Looks like that is a complete assembly with housing, about $300. The speaker is not likely avail by itself.
Nice that MontanaBronco is offering you one!
Ducati1098
Yep, not available separately.
Montana Bronco
Montana
Chevy
Just to be clear, what I have is the non-functional amp and subwoofer. I took that out and put in the JL Audio subwoofer and amp.
Plenty of threads on here of people putting a functional amp and speaker in it. Basically what I would be sending you is a piece of plastic.
Im loving the sound of my JL Audio sub, I think they call it “stealth box” because it fits perfectly in place of the factory subwoofer. Looks factory but sounds luxe.
pizzy
pizzy
larry
Pa
2023 bronco base
oh i see... yeah thats what i have now and am in the process of sorting out the parts needed to make it functional again.. the amp is easy enough to source and the kicker sub is as well but i wanted the original functioning speaker to try and reassemble the oem setup
thanks though
pizzy
pizzy
larry
Pa
2023 bronco base
i guess back to the original question anyone know if the subwoofer speaker is available to purchase alone without the enclosure and what the part number might be?
mpeugeot
I actually have the subwoofer out of my Bronco (B&O) but it should be the same. If you want it, it's yours for the shipping cost. I will verify it fits the non B&O enclosure (I have 2 Broncos so I have both enclosures). Send me a DM.
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
The B&O speaker is larger(almost 8”). For a near OEM replacement you can use the Kicker 6.75 subwoofer. Fits perfectly. Folks have also been using a Ford Fusion amp since it utilizes the same OEM connector. Many threads about this.
I will maybe have a stock 7-speaker sub once I get around to installing my new system.
Here is a video from a forum member to help
pizzy
pizzy
larry
Pa
2023 bronco base
yea I’ve read most of the posts regarding the fusion amp and the kicker. I really wanted to try and locate the original sub speaker driver rather than go with the kicker I already purchased the fusion amp so I just wanted to see what the original speaker might cost to replace my dummy speaker.
BigHoof
PA
Ram 2500
Not many out there to be had. The sub in the stock system was new for 2023. Ford put a few in until mid Dec then the delete was mandatory. Restarted a few months ago. Weird you can't buy just the speaker and have to get the entire enclosure. Probably in short supply.
pizzy
pizzy
larry
Pa
2023 bronco base
Oh so the woofer is not available as a stand alone part. only part of the complete housing?
Ducati1098
Yes. It’s only available as the whole housing.
Ford Bronco part number for oem subwoofer? IMG_2158
