parking sensor issue...hope you guys have an answer
vgodley1
Vee
Humble TX
Ford Bronco
I purchased my Bronco Badlands SAS on Aug 10, got hit by someone running a stop sign on Aug 18, and finally got my Bronco back on Nov 15th, YEA! As they had to replace the bumper I got them to upgrade the bumper from the capable to the MOD. the issue is that the MOD bumper uses the same harness but a different sensor part number than the capable and the result is that the parking sensors are throwing an error code and won't work any longer. I had a dealership perform the repair work (they did a great job) and they say they can't correct this and i have to modify the mounts to install the old sensors. does this make sense to you guys, I have to believe that this is a simple programing thing to correct? any suggestions would be greatly appreciated as I do want the full functionality of my vehicle.
Thanks
vgodley1
Vee
Humble TX
Ford Bronco
Thanks
Any of you Forscan experts have any solutions?
Felix808
SRV CA
Not sure about the differences in the harness, but I would check the wire connections. They all use the same type of plugs but one is for the license plate light if I recall & can easily be plugged in to a sensor instead of what it needs to be plugged into resulting in the same issue.
Also make sure the sensors are centered in the bezels.
GLWI 🤠
vgodley1
Vee
Humble TX
Ford Bronco
GLWI 🤠
Thanks for the response, this was the front bumper.
Eroc88
Ohio
Jeep
Only the driver and passenger outter parking sensors are a different part numbers bc of the angle on the connector are different. I swaped out my capable bumper to the mod bumper using my stock harness. The sensor retainers on the capable bumper will not work. I had to order 4 sensor retainers that are specific to the mod bumper and the 2 outter sensors in order for it to work.
Part # LU5Z-15K859-AAPTM are the outter sensors needed.
Ford Bronco parking sensor issue...hope you guys have an answer Screenshot_20231124_230014_Chrom
Bulldawg9
Bandera tx
2023 wildtrack
GLWI 🤠
I did that exact thing drove me nuts for an hour or more trying to get them to clear.
Wolford678
J
GA
‘21 Bronco Badlands
Seating connectors until they click. You might have to push something plastic down inside the connectors with a screw driver to get them to seat properly. Also spraying the connectors with WD-40. These things helped my warning go away. But it sounds like you may have a more technical issue.
