Parking Brake Fault Has to be Towed
pfbz
CO
F150 Turbo, 991 Turbo S, 996 turbo, Q5 Turbo
Electronic Parking Brake (EPB) Manual Release
Activation
NOTE:
If the EPB cannot be released using the switch carry out the following procedure. If the battery is dead, jump start the battery to provide power and release the EPB using the switch.
NOTE: Typical parking brake actuator motor shown.
  1. Block the wheels and tires.
  2. Disconnect the parking brake actuator motor electrical connector.
@Bmadda,
Sounds like exactly the procedure the OP needs!
Can you perhaps save/repost that as a screen capture or pdf file? It looks like html cut/paste with much of the useful information missing....
Broncobren
Matt
WT High Pkg MIC Mod Bumper
Electric parking brake is the dumbest idea since frozen toast.
How does Ford take something as simple and reliable as a parking brake and fudge it up.
It’s not just Ford, most makes of vehicles have them.
drew707
Ford Explorer
Activation
NOTE:
  1. Remove the bolts and parking brake actuator motor.
  1. Rotate the ball screw driveshaft clockwise 360 degrees.
  1. Repeat steps 2-4 on the opposite side of the vehicle.
  2. Install the parking brake actuator motors.
    Refer to: Parking Brake Actuator Motor (206-05 Parking Brake and Actuation, Removal and Installation).
Maybe we can find someone to make a jumper harness long enough to reach the vehicles battery. That can be a primary attempt to releasing them before resorting to having to pull the cover off. I have had to do this before on a different vehicle.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I don't think that is a good idea, as you have no torque control. The actuators are wired direct to the ABS module, which must use "amp out" for force control. You would likely break them if you powered them directly.
drew707
Ford Explorer
Interesting I’ve never once had any issues and have done this a handful of times. It’s how I’ve had to set parking brakes on dead vehicles in the past. You could be right though. I know window motors have this same feature but it’s built into the motor itself
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
I wonder if they are using theses on the trail turn asst?
mspeter
MP
NorCal
‘22 Badlands 7-spd, ‘20 F350 Dually, & 3x M422A1s
Not a desirable event to have a failure 30 miles off pavement in the desert.
Please post the details of the actual fix
The manual release appears to be another internal Torx+ bolt. Anyone know the size ?
Earmark it for a must-have in the spares/tool kit.
Bmadda
Wisconsin USA
Not saying you can't do it and be fine...just don't wanna reccomend that to somebody and have them break something
Tony
Dublin, NC
2021 2dr Bronco Badlands
Thanks for the advice. Pretty neat idea
Carbon Bronco
Washington
1969 U15 Bronco New Lime 302ci
Or a few scoops of Murphy tire mounting compound, aka snot.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
On the bright side you might win the lemon law if the issue does not get resolved after multiple services
Why are so many so quick to turn to lemon law? I'm not anxious to start another 2 year wait for another one, I'd want mine fixed.
Ares
Fox
Atlanta
theres definitely something wonky with my parking brake as well, and I know at least 1 other poster here with an issue.
mine hasnt stuck on though, it just throws a bunch of errors and makes me push it off manually. so far...
Ill be in the dealer Tuesday for diagnosis.
