Parking Brake Fault Has to be Towed
Tony
Dublin, NC
2021 2dr Bronco Badlands
Went to leave my friends last night. Got in to crank it up and noticed the brake light was on. Hit the button wouldn't release lt. Tried to engage and then disengage it. Screen shows parking break fault needs service warning. Went back this morning and pulled the fuse and the wiring harness off still won't clear it. Tried rocking it and disconnecting the battery no dice. Call roadside assistance and the first guy was terrible. Told me there was nothing he could do as my dealership is closed today. Then wanted me to call my insurance company. I hung up and got in touch with a much better associate. Still can't be towed until first thing tomorrow morning. I ended up being so frustrated messing with the button I pull it off lol. Love the vehicle but 3 weeks old 1600 miles this is ridiculous. I don't even know how there going to get it on the rollback tomorrow.
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
On the bright side you might win the lemon law if the issue does not get resolved after multiple services
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
Electric parking brake is the dumbest idea since frozen toast.
How does Ford take something as simple and reliable as a parking brake and fudge it up.
NC_Pinz
Central NC
If the rollback can back up to it, they will get it on the truck. Their winch will overcome the friction of two tires not rolling. Consider what thieves do when they use rollbacks to grab cars.
ILoveTacos
Eastern Shore Of Maryland
Subaru Outback, Honda Pilot
Oh man that sucks. Hope it's a quick fix for you and that it doesn't happen again.
NC_Pinz
Central NC
I'm hoping that someone digs into the Bronco after some time to see if there is a way to disengage the electronic parking brake manually. Would stink to get into the boonies and have this happen.
Tony
Dublin, NC
Tried to drive it almost pedal to the floor and nothing. And I understand with the rollback just don't see how it's good for the bronco.
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
Try unplugging it, and plug it back in. I had to replace mine the other day. Here is the thread where I replaced it.
Electronic Parking Brake Handle/Light Control Module Replacement
Tony
Dublin, NC
Tried unplugging it didn't clear it. Didn't leave it disconnected for long. I wouldn't think that would matter
WuNgUn
Ontario Canada
2 door Squatched
Not that it matters, but the hill hold assist uses ABS brake actuators, not the E-brake. Hope you get this settled. Frustrating...
760 bronco
Palm Springs
Bronco sport
Did you try placing it in drive? My 22 pathfinder turns off the electronic parking brake as soon as you slide it into drive.
Worth a shot
Tony
Dublin, NC
Yes put it in drive and tried to floor it almost. Barely moved
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Electronic Parking Brake (EPB) Manual Release
Activation
NOTE:
If the EPB cannot be released using the switch carry out the following procedure. If the battery is dead, jump start the battery to provide power and release the EPB using the switch.
NOTE: Typical parking brake actuator motor shown.
  1. Block the wheels and tires.
  2. Disconnect the parking brake actuator motor electrical connector.
  1. Remove the bolts and parking brake actuator motor.
  1. Rotate the ball screw driveshaft clockwise 360 degrees.
  1. Repeat steps 2-4 on the opposite side of the vehicle.
  2. Install the parking brake actuator motors.
    Refer to: Parking Brake Actuator Motor (206-05 Parking Brake and Actuation, Removal and Installation).
Ford Bronco Parking Brake Fault Has to be Towed pbimg1
Ford Bronco Parking Brake Fault Has to be Towed pbimg2
Ford Bronco Parking Brake Fault Has to be Towed pbimg3
