Oil Catch Can??
Zinn
Minnesota
2016 Mustang GT, 2020 Ranger Lariat
Dang, I want to install a catch can, but live in the MN cold. Making me think twice now.
I live in MN, the can on my Mustang fills up a bit faster in the winter but nothing like that. I probably empty it once a month in cold months.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Any problems with freezing can/line?
dejones64
Dan
MN
I see a lot of these catch can installations with the can higher than the hoses. Wouldn't you want the can lower than the hoses so they drain into the can?
VelocityBronco
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
It doesn't drain really, it separates the oil from the air that is being sucked through the PCV lines, and the oil falls to the bottom of the can as the air passes through. So unless you mount it upside down, it will still capture the oil, or most of it...
The Pope
Also with the can higher, any oil residue in the line going to the can, can theoretically drain back to the engine.
There are even Catch Cans which have a hose off of the bottom that lead back to the Oil Pan. So you never have to drain the can, as it's constantly returning the oil to the oil pan.
VelocityBronco
VelocityBronco
E
Are you kidding me, @The Pope just commented on my thread!! And a Bronco fan!!! Suck it Jeep! Haha
Is it just clean oil that gets trapped, or any other vapors, like water that you wouldn't want to drain back to the pan?
Someone earlier said they had a freezing issue, and oil doesn't freeze, so...
guzie
Kevin
Grand Rapids
2019 Subaru WRX sti, 2019 Ford Mustang GT
Dang, I want to install a catch can, but live in the MN cold. Making me think twice now. Can at least use for summer months only I guess.
They are fine all season
dejones64
Dan
MN
It's the water condensation during winter months, possibly freezing. But replies have said it should be good all year round.
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
BTW .. I have never know anyone to be denied a warranty over a catch can. BTW, a catch actually helps the engine run cleaner.
https://www.camaro5.com/forums/showthread.php?t=451361
" After a two week battle with the dealer and GM they blamed my catch can and blocked my warranty giving me no explanation on how the catch can caused any failure and now have walked away from an 11 month old car with 11423 miles on it. "
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Amazing. I am glad this was such a detailed account of the issue. It seems like the dealer was looking to dodge the repair and used the catch can to do it. It interesting to me what the motivation would be. Looks like a Ford Motorsport catch can might be a lower hassle option when under warranty.
Stitches1974
SW Florida
If Ford adds it to the B&P and warranties it, I'll put one on no problem. If not, it won't see one. The 6.4 in my avatar will never see a catch can.
Raptor911
Raptor911
Broadlands, VA
That sucks. I am still installing one on my Bronco and then removing it if I need to go to the dealer. MY advice ... if you are buying a bronco NOT to install one.
Lightning rarely strikes a person BUT if you are struck once then I guess it can happen to you again.
