Oil Catch Can??
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
Does anyone believe Catch Cans are "required" equipment on the Ecoboost engines? I have had a 3.5L Ecoboost for 8 years without a CC, but I have had the engine shudder issues in the past with it...but still never installed one. I did have to replace a turbo on it, but not sure if that is related or not...
Has anyone installed on an Ecoboost? Going to install again for your Bronco?
DYI project or wait for a complete kit to come out specifically for the Bronco?
I have read they are more important for Direct Injection engines, so this would apply to both the 2.3 and 2.7 engines in the Bronco.
Also, what are other Mods that are recommended for Ecoboost engines, for reliability and/or performance?
Raptor911
Raptor911
Broadlands, VA
I think all 2.3 owners should install one because the 2.3 does not have port injection.
Someone posted images of the 2.7 engine bay the other day and installing a catch can on the 2.7 will be easy.
I ran a JLT on my 2013 Raptor and currently running one my 2019 Raptor. I am sure JLT will have an application for the Bronco.
There will be lots of debate on whether a catch can is needed as there are on many forums.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
My understanding on the 2.7 is it uses both direct and port injection, which reduces the carbon buildup issue. If I go 2.3 I will likely add a catch can. 2.7 seems more optional. I like the idea of a lighter front end , but also love my current 2.7. The torque and horsepower are just addictive!
VelocityBronco
VelocityBronco
E
From what I understand, its not a carbon buildup issue, more of a oil getting sucked out of your crankcase and put into the intake manifold, than collects in the inter-cooler and intake valves, gunking them up.
Has anyone had the shudder happen to them with the 2.7? It was a well known issue for the 3.5 F-150 for a while.
Brocked
Brock
H-Town, Texas
Lots
I used them on my 2011 5.0 when I had it. It worked. Drained the oil every other oil change or so. Never a lot, but worth the peace of mind. Ill be getting them again. Very easy to install, at least on the Mustang.
Used2jeep
Massachuvian
2007 Crown Vic P71
I've never touched a turbo motor before and I saw that picture. Not sure how it could be "easy" to fit more stuff under that hood. You could throw a fistful of small sockets in there and NONE OF THEM would fall to the ground!
Raptor911
Raptor911
Broadlands, VA
a catch can is tiny. It is smaller than a can of mini coke. Trust me .. there is room and it is an easy install. It will take you less than 10 mins to install it ... at least the one from JLT for the 2.7
Going to take a pic of the one in my 2019 Raptor and show you .. brb
JLT Catch Can on 2019 Raptor. It comes with hoses and all the necessary fittings. It actually uses Ford OEM quick connect hoses so literally you twist and pull off. You don't need to cut any hoses as it comes with the correct size. I am sure they will make one for the Bronco in both engines:
Ford Bronco Oil Catch Can?? 1600183811205
Used2jeep
Massachuvian
2007 Crown Vic P71
a catch can is tiny. It is smaller than a can of mini coke. Trust me .. there is room and it is an easy install. It will take you less than 10 mins to install it at least the one from JLT.
Good news then. I'm fairly capable. "Capable" defined by friend is vastly different than being defined by wife ("Maybe we should call <so and so> to do that.")
lobbs611
Kyle
Independence, MO
2D JL Rubicon
I think they're almost a requirement these days as most modern PCV systems are designed to dump any oil vapors collected back into the airstream to be burned off. This naturally coats your intake and valve train with oily goo. The manufacturers know all about it and that's why they offer those "upper end" cleaning services at the dealership. It's a money maker for them. The reason they don't install catch cans on anything but a handful of performance applications from the factory is that they don't trust the average customer to drain the things periodically.
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
To be honest brother, if you go with the 2.7L V6, you shouldn't have to install the catch can due to the addition of port injection. With the 2.3L I4, I would install one just to be safe as it can't hurt. it's just an additional step in your routine maintenance to empty the cans. That's just me though. I'm right there with you on the 1st gen 3.5 Ecoboost. My 2011 Lariat Ecoboost is at 170K miles and all I've ever had to do to get rid of the shudder on startup and heavy load is the 1/16th weep hole in the bottom driver's side corner of the intercooler and replace the spark plugs and coil packs. Runs like new again. I also added a custom 93 octane tune from 5startuning. My truck with flat out tear up some asphalt.
Hkak45
K
Illinois
21 Bronco Black Diamond
If catch cans are needed why do we not see it on any motor from the factory? ?‍♂
Mattwings
Matthew
Northville, MI
I am not a technical expert, but my guess is emissions are the biggest issue, not servicing. This is part of the PCV system and the expectation is the oil/fuel is burned. There is probably evaporative emissions issues the cans run afoul of.
FourHorses
Currently own 6 Fords
Little more involved on the 2.3 due to placement of the PCV, but still pretty straight forward.
I’d assume this would be a similar install on the Bronco as it is on the Explorer.
JLT install on 2.3 Explorer
