OBX to Badlands Stance
KitsBronco
Tom
Vancouver, BC
Triumph Street Scrambler
Hi all - I have been looking through lots of threads and there has been a lot of good information but I am trying to gain a clearer understanding of ride height between OBX and Badlands. I am going to be throwing 285/17/R17 KO2s on my OBX and am curious what lift I would need to give it the same stance as the badlands with the KO2s? Do both also have the same amount of factory rake?
Any help is much appreciated!
RagnarKon
Ford Bronco, Escape, Focus
Worth noting before I dive into this that 285/70r17 will fit on an stock Outer Banks without any modifications.
But anyway… if you are just trying to get a similar stance all you need is a 0.67” lift with both front and rear (meaning the rake is unchanged). Which can be achieved with a spacer.
If you want the same amount of suspension travel as the Badlands obviously that’s going to require new coil overs. The Badlands has 0.85” increased travel in the front and 0.4” increased travel in the rear.
603BB
NH
Bronco Outer Banks
Well maybe. Depends on what kind of wheels (offset) you have. I have the OBX (non-SAS) and I just put 85/70R17 Falken Wildpeak A/T on Method 17x8.5 (0 offset) on it. There was rubbing against the crash bars (steering wheel turned both directions). Had to remove them. I was surprised. Thought I did my homework but missed something along the way.
Ford Bronco OBX to Badlands Stance 20220616_115857
RagnarKon
Huh… that is uhh… interesting and defies logic.
The stock Badlands trim has 285/70r17 tires with +55 offset wheels and it includes the crash bars. You would think that lowering the offset would make the crash bar clearance even greater.
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
OBX has 18" wheels standard. You can't put 285/70/17 on 18" wheels
‘21OBX
90Bronco19
2022 bronco outer banks
The easiest way would be to buy a set of takeoff badlands coil overs. $1200 ish bucks but you get the .6” lift and better shocks so not a bad value. Here is a pic of the stock badlands wheels on my OBX. The tires come about flush to the flares and no poke.
Ford Bronco OBX to Badlands Stance E9F4FA39-6473-4B25-80C2-A02108CEA51E
Ford Bronco OBX to Badlands Stance AAF4A3CB-94EC-46E5-A4AE-9B4989A25B6D
603BB
NH
Bronco Outer Banks
Correct. New 17" wheels for me. In my case, Method 17x8.5.
603BB
NH
Bronco Outer Banks
Here are some pics with the OEM crash bar and this wheel/tire combo that was a problem with full steering wheel deflection.
Ford Bronco OBX to Badlands Stance 20220623_181601
Ford Bronco OBX to Badlands Stance 20220623_181621
And the replacement crash bar.
Ford Bronco OBX to Badlands Stance 20220623_183008
Ford Bronco OBX to Badlands Stance 20220623_182952
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
Before I changed shocks, I had 285/70/17 KO2 on 17x8.5 wheels with +25 backspacing. No rub on stock OBX with crash bars installed. Then upgraded to Badlands coilovers and front level kit.
Bemcnamara
Brad
Coeur d'Alene Idaho
2015 F56S MINI
Where did you purchase the new crash bars?
Bob L
none
Thanks for the pictures of the aftermarket crash bars, wondered how they looked bolted on.
JustinZ
Justin
Chesapeake, VA
'22 Badlands
Too bad you're not closer to me. I should be taking delivery of a badlands with the optional wheels and KO2s in a couple of weeks. The suspension, wheels, and tires are all coming off day 1 and will be for sale.
SeaVee
Greg
Va Beach
2002 2500 Suburban, 77 Bronco, 2001 Cherokee
295/70/17 on stock OBX with Badlands rims.
JustinZ- might be interested in your rims/tires. I’m in VB
Ford Bronco OBX to Badlands Stance BF3CED94-41F1-4537-BF7A-86E8A42A21E3
603BB
NH
Bronco Outer Banks
