Not receiving ota updates anymore
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
I just got my first update in over a year of owning my bronco. I can’t imagine they push them out that often?
HotdogThud
mk6 gti, '21 MoarDoor
There are certain things I can see with the VIN in PTS, but I am not sure I fully understand your issue. What do you mean by "safety pause?
Android Auto is now forcing a Safety Pause after 5-6 taps. So no interaction, mutes the audio, and generally halts the whole screen until 3-4 seconds pass.
There's defeat devices out there that typically solve it by shorting the e-brake line, so the system thinks the ebrake is applied, and thus negates the pause, or tricks the system into just not reporting the speed of the vehicle to the head unit.
But noooooo, Ford thinks it's unsafe to interact with the vehicle unless it's in park. Not even stopping the vehicle *while in drive* is enough to defeat their dumbass safety pause. Kinda like how native Sync will keep you from searching for music on an attached USB drive unless the vehicle is fully stopped.
my fuel pump is under recall, with no end in sight, and they think my front seat is going to explode out of the car at any time, and won't fix either of those things, but they put effort into changing this to fuck with drivers?
this is the kinda stuff that's going to drive me to start trolling Mike Levine on twitter again
Glade Runner
Everglades
VA
Yes
Everglades
Is this the defeat device? https://www.4dtech.com/canopener-motion-unlock-for-sync-equipped-vehicles/
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
That would annoy the hell out of me. I assume this is a Bronco or vehicle specific issue, because I've never had that happen to my F150 or our Bronco Sport which are both on Sync 4. Maybe there's some way to turn it off with FORScan, but I don't know of a way. Wish I could be more of help, but unless the issue is specific to your Bronco, I don't think I can do much with your VIN in regards to this.
HotdogThud
I am 5000% certain that any troubleshooting would involve ford going "oh, that's an android auto thing!" and google going "nope, that's ford reporting the wrong data back to android auto"
rugedraw
Javier
Miami, FL
I'm on Android, too. For sure it's not an Android thing.
dothadewman
mike
#357Magnum
2023 Bronco Big Bend w Sasquatch
I have a 23 with auto updates on recurring at 1am I’m on version 4.0.23353 and have not received any updates since at least may of 25 when we purchase. ..I contacted ford and they csn ping it and said possible battery voltage was preventing, but battery was replaced and still no dice.
crenca
Southern New Mexico
If it was me at this point I would use forscan to check the DTC codes and the battery state of charge and go from there.
rugedraw
Javier
Miami, FL
Low battery voltage will not prevent updates from being sent, but it can prevent them from installing if one is sent. Particularly the ones that require the vehicle to be inhibited while they install.
dothadewman
mike
#357Magnum
Yeah I’m not sure what’s going on then.
CarGuy
New Jersey
2023 Ford Bronco
I have a ‘23 and have not seen an update for quite some time. I assume as the vehicle ages the number of updates will decrease to the point where only critical/required updates will be performed - e.g., security, safety, etc.
Area51BS
Ron
Badlands non SAS 4dr 2.3
There is only so much that can be fixed from original vehicle design with updates. At some point parts or mechanisms must be redesigned. If manufacturers used a poor chip or poorly engineered part it can’t be fixed with an update. Example. An update can’t fix the scotch tape interior plastic.
rugedraw
Javier
Miami, FL
It doesn't necessarily mean that something is going on. The OTA process for Ford and all legacy manufacturers is inconsistent, unpredictable and unreliable. Sync 23353 is two versions behind the latest available Sync.
dothadewman
mike
#357Magnum
Ford says they cannot see any of my modules or when they last received update. My actual version from the about screen is 4.0.24240 which is current but she said I should be getting other updates My vin is 1FMDE5DH3PLB30648
rugedraw
Javier
Miami, FL
The people that answer the phones when you call Ford read from a script and are clueless. They 100% can see what modules have pending updates, but they often do not know how to use the resources they have in front of them.
Unfortunately, due to some recent cybersecurity changes that Ford made, I am no longer able to check for pending updates. My PTS access was nerfed and I let my FDRS license expire since Ford is now banning accounts for running VINs through FDRS without being plugged into the vehicle. I think @flip is still able to check for pending updates in PTS. Maybe he will chime in or you can message him.
What I can tell you is that connectivity is working just fine in your truck. OTA history is stored for 180 days on the cloud, and it shows no updates have been sent to you in over 180 days. Also, according to this document from Ford, Sync 24240 is the latest available for your truck. I know this document is not 100% accurate (my F150 is on Sync 25094 and this says 24127 is the latest), but if you are on that Sync, you can't be too far behind. My Bronco Sport that I installed a Sync 4 APIM in is also on Sync 25094.
Ford Bronco Not receiving ota updates anymore 1770482621553-rt
