Any OTA Updates Recently?
Dexter18
Edward
Nanuet n.y.
2023 colorado ZR1
Since Friday 1/14/25 every time I start my 2024 OBX my dash lights up with PARK AID FAULY, SERVICE ADVANCE TRAC,PRE-COLLISION ASSIST NOT AVAILABLE. Were there any OTA updates made recently????
T,,
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
OTA updates are done in waves/stages, not every vehicle gets them at the same time.
You'd have to provide your VIN to a dealer employee who can look up your vehicle in OASIS—internal dealer service system. It'll tell them whether an OTA was applied recently or not.
FleshTuxedo
A
PA
'22 OBX 2dr.
Can't you check in the FordPass app?
crenca
Southern New Mexico
This app is pretty limited, at least in my case with a manual and without remote start.
Opening it up and going to settings>software updates shows me "automatic updates" set to on and "reoccurring schedule" not set. Poking around in the rest of the app, including messages, does not indicate anything about OTA and whether one was applied or not...am I missing something obvious?
I do recall a message showing that an OTA was applied when I started the vehicle once a few weeks back but that message was on the dash.
Bugkillah
Keith
North Augusta, SC
Base Sas, Badlands, Wrangler, Nissan Frontier
I just got the update to stop the window drop on unlock. But why?!?!
Huntsetter1
Hopefully they fix car play so it connects every time so you don’t have to reboot!
RoverDude
Maryland
2021 Bronco (First Edition)
T,,
Just a thought, is there any chance you have snow/ice on your bronco?
Settings -> Software Update -> Release Notes
That will show you the most recent OTA update installed. And the timestamp of when it was installed.
I don't think it deletes them, it just shows the most recent. Mine is still showing one installed back on Dec 19.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Everything in mine is working pretty good right now so I figure an OTA update has to be right around the corner to fix that
crenca
Southern New Mexico
Huum, taping Settings gives me two choices, Software Updates (with an s) & Vehicle Access. Taping Software Updates gives me the two "choices" I mentioned before, except they're not really choices because if you tap on them to make a change the app just gives you a help page instructing you to go into your Bronco and make any changes through the dash screen. In other words no Release Notes...
I'm on an Android pixel phone, so maybe the FordPass app is different for different OS's??
Keith J.
2024 Bronco
The last OTA update that I was supposed to receive failed. That was on December 4th. The one before that seemed to have taken away the animation on the infotainment screen and replaced it with an outline of a Bronco logo. I'm kinda salty about that because I liked that animation. Anyone else have that happen to them?
LMG
Tupelo, MS
2024 Bronco Raptor 2026 F450
First thing I would check is the battery. My 450 will trigger all kinds of warnings like that when the batteries are weak.
Think about it like this. The Bronco has a series of computers that fire up in series at startup. A weak battery doesn’t properly awake all of them hence the warnings.
jrollo7
James
NY
Range Rover Sport
Yes. Now the outline. Original startup image is gone and replaced.
ONEBronco
Keith
Omaha, NE
2022 Bronco
Yeah the rolling rock bronco animation is gone, which seems to make the infotainment start up much faster and less glitchy than before.
